'09 Cub cadet LTX1040 - won't start-
   / '09 Cub cadet LTX1040 - won't start- #21
when at TDC on compression stroke you should have a couple of mm of 'slop' on the valve stem. I measure the 'American way' in thousands of an inch. :)
good luck.
SUCCESS!!!! sorta....
Mower running great, sounds great, mowing great....but now there seems to be a problem with the tranny.- CVT with 2 belt system is what my research just told me..
If I go up the slightest of inclines whether the PTO/blades are engaged or not, it slows to a crawl and will stop if I push all the way down on the forward/reverse pedal. If I ease off the pedal, and then push down again, it will go, but will repeat the sequence.
Here we go again, lol. Haven't had a chance to research this problem yet...any insight? Common issue?
   / '09 Cub cadet LTX1040 - won't start- #23
   / '09 Cub cadet LTX1040 - won't start- #24
are you sure it's not an HST? My 1046 is. What you're describing with the way you're using the pedal sounds like it's an HST. When under a load you need to back off on the pedal with an HST...this puts it into a lower 'gear'.
What happened with the engine?
Well, I went back out, looked around the pulleys, grabbed one or two, kicked the tires and went for another test run.....and it drove great. Didn't slow down on the gentle inclines, accelerated smoothly, no whining or strange noises....IDK what happened, but what ever it was, it's not doing it anymore.
Thanks Thomas - I'll look around for leaks and what not but I didn't see any initially.
Pilgrim - It's a CVT with 2 belt drive system. I have a FWD gear, a N position, and a REV gear. When I push the clutch/brake pedal in, I put the gear shifter into F or R. When I let the brake/clutch out, the mower doesn't move until I push on the right pedal. Which is the way it is supposed to work.
Same goes for Reverse, shift into reverse, let brake/clutch out, and then push on the right pedal to move in reverse.
As far as the engine goes, I'm thinking it was just the EX valve loose again...maybe the push rod 'jiggled' out of the valve arm thing when I did the install...IDK...operator error most likely. At that point though, I decided to tear it down to the crankcase to see if the cam gears were good and whatnot.
Everything looked good on the motor, got new closure gasket, put everything back together according to the Kohler service manual -including setting the proper gap on the ignition module...I stumbled across that section in the manual...I would've had that wrong for sure.
Sanded down the ignition coil/module and magnet on the flywheel, inspected wiring harness....(found one bad spot near the coil and put 8 layers of electrical tape on it and routed it to where it wouldn't rub anymore).
New plug, filters, oil....
And it's running and mowing just fine. Cutting better than my JD L100 with a 17 HP INTEK BnS.....same size mower as the CC basically.
Question: When I shouuld check the valves again. Before I mow again?
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
