09 5045d
/ 09 5045d #3
As already stated need more information, but on a hunch.
Are you blowing any fuses? And does the fuse blow as soon as you turn the key?
If yes, to both questions, I believe the problem is the thermistor sensor (thermistors are temperature variable resistors used as sensors.). On the thermostat housing there is a sensor that is connected to a two wire harness that goes to the injection pump; this is the "cold start advance" portion of the system so it starts easier when cold by advancing the timing.
When the sensor on the thermostat housing fails it shorts out and blows the fuse. Try unplugging it, replace fuse and see if it starts and runs. The part # is RE503242, if you are quick changing it, you don't have to drain the coolant, just make sure it's not hot at the time. You will want a pan under the tractor to catch the coolant, so as not too have to clean it up.
To comply with the exhaust emissions regulation, the timing of injection pump should be around 6 to 9 degrees before TDC. These timing values do not allow proper start-up operations when engine is cold. To ease engine start-up, a cold advance system gives to the injection pump a temporary over-timing.
When coolant temperature is below 50 C (122 F), the solenoid valve is activated and opens the cold advance circuit.
/ 09 5045d #5
Oh! Oh! ........ I love these!
JD will not start..........Hummmmm. It's the internal galectaziod defribulator! Wait, wait, ...... Maybe the Flux Capacitor......
All joking aside, you will get much more value from these forums in helping your issue if you would include more information.
Cheers,
/ 09 5045d #6
/ 09 5045d #7
I suspect he got it started as he hasn't come back to check with us. Probably didn't have it in park.
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
15ft. Hay Rack (A65640)
15ft. Hay Rack...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
