08 ct335
/ 08 ct335 #1
swampertrac
ct335 bobcat
my ct335 shut down just like i turned the key off, i have no dash lights except the glow plug light when key is turned to preheat. I get a click from the ignition switch relay and the glow plug relay ,but nothing else. and no start with key. it seems like a wiring problem or fuse but the fuses are ok. I'm about to take the dash off. Hoping someone else has had this happen. Any help would be greatly appreciated
/ 08 ct335 #2
Check all your electrical connections, fuses etc
willy
/ 08 ct335 #3
Remove cables from battery. Have battery load tested. Clean battery posts and cables. Inspect cables for breaking down. Replace cables on battery and tighten securely. If you can move them they're not secure. Follow ground lead to frame. Clean and tighten the connection. Now we start troubleshooting.
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
iDrive TDS-2010H...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
Kubota MX6000 (A64126)
