08 ct335
   / 08 ct335 #1
swampertrac
ct335 bobcat
my ct335 shut down just like i turned the key off, i have no dash lights except the glow plug light when key is turned to preheat. I get a click from the ignition switch relay and the glow plug relay ,but nothing else. and no start with key. it seems like a wiring problem or fuse but the fuses are ok. I'm about to take the dash off. Hoping someone else has had this happen. Any help would be greatly appreciated
   / 08 ct335 #2
Check all your electrical connections, fuses etc
willy
   / 08 ct335 #3
Remove cables from battery. Have battery load tested. Clean battery posts and cables. Inspect cables for breaking down. Replace cables on battery and tighten securely. If you can move them they're not secure. Follow ground lead to frame. Clean and tighten the connection. Now we start troubleshooting.
2012 Hyundai Sonata LIMITED (A50324)
2012 Hyundai...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
