'07 B series rumor mill?
   / '07 B series rumor mill? #51
Gardener:
All modern tractors with a three point hitch have position control. Few or no compact tractors have draft control nor is this needed unless you wish to plow.
If you want to "drop and go" with a three point rotary cutter buy any tractor with position control, e.g., just about ANY tractor and an appropriately sized mower.
To make your life just a bit easier, install limiter chains on the mower.
Dean
   / '07 B series rumor mill? #52
SDT said:
Gardener:
to make your life just a bit easier, install limiter chains on the mower.
Dean
With any three point hitch it makes for an accurate height adjustment that you can;t get with any other system.
Any mower should cut on the front!
   / '07 B series rumor mill? #53
SDT said:
Gardener:
Dean
Except the BX Kubotas, the B7510, 7610, 7800, etc. That makes for a pretty significant sector of modern tractors that don't have position control, and a pretty sizeable portion of annual compact and subcompact tractor sales.
   / '07 B series rumor mill? #54
My decision is made ... I will look to a tractor with either a MMM or a RFM to handle our 7+/- acres of lawn cutting. And, I am going to be certain that the PTO has "position control". It definitely matches my inexperience level. And, I think it would have better re-sale value should that become important.
I'll certainly look into the limiter chains, but I don't imagine that type of exactness and accuracy will be needed on the acres that I'll cut with this tractor. I'll still use our 42" riding lawn mower to handle the immediate lawn around our house, the gardens, and the barn, and perhaps a couple of super laps around the entire woods line to handle the cutting under the over hanging limbs. That equates to about 20 +/- minutes of cutting.
By time we are ready to make this purchase, there should be some very nice B3030 tractors on the used market which would be perfect for our budget.
   / '07 B series rumor mill? #55
Mr. White said it all here!
Check chains to limit downward movement..
Like they say in the Ronco commercials..."Set it and Forget it"..
Alot cheaper and more accurate than Position control.
   / '07 B series rumor mill? #56
There are some very nice B2910's around used, with low hours, and they have all the bells, and whistles including position control. Don't overlook them in your search...... very comfortable machine, and the same size as a b3030
   / '07 B series rumor mill? #57
PTO= Power Take Off. Turns the shaft supplying power to mower or attachment.
3PH= Three Point Hitch. Raises and lowers attachment. Position Control is part of this system.
As already stated. There are many B2910 out there that will meet your requirements. A 72" MMM on this tractor will cut 2 acres of lawn per hour.
   / '07 B series rumor mill? #58
Provided that lawn is nice and smooth. 72" MMM + uneven terrain = bad plan. 60" MMM handles it better and as a result gives about the same productivity.
   / '07 B series rumor mill? #59
Rumor addition.... BX 2650 is coming next year.
   / '07 B series rumor mill? #60
Boy this has got to be the best example of hijacking a thread I have ever seen.
On 12-8-2006 WayneW ask:
Has anyone heard of an '07 (or '08?) replacement to the aging B7800?
On 12-12-2006 WayneW ask:
So no one has heard of a B7810 in the works?
On 7-6-2007 Markanth ask:
Any information on the replacement for the B7800 to be introduced at the Oct. dealer meetings? hp pto etc?
58 replies, not one direct answer, 99.9% replies are about quarter inching valve Vs position control.
Just so WayneW can have one answer: I have not heard of an '07 (or '08) replacement to the aging B7800. Of course they dont let me out of the home much anymore, so I really dont know.
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2430 (A51248)
2430 (A51248)
2019 INTERNATIONAL MV 16' BOX TRUCK (A54607)
2019 INTERNATIONAL...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2013 Ford F-550...
