'06 T330 HST Fuel Filter Assembly
   / '06 T330 HST Fuel Filter Assembly #1
MoMatt
Clayton, WA
2006 TYM T330 HST
After replacing the fuel filter, I noticed the fuel lines on either side of the filter are clamped to a 90deg fitting that seems to be just pressed in to the filter housing.
Both sides just pull out. This seems to create a slow diesel drip on the injector-side hose.
Are these normally just pressed in, or did a factory adhesive fail? Would a little JB weld or epoxy on the 90deg fittings be a reasonable solution?
sLKAnKXrgf9N-M3oZWeO7BzjJ3fTxnNMHixksFEAS78wrVwisxpP4HIzaPqhh_8egI9eTP1Wxb5BnPGLR9spCu5QPTJ-DusSNqqJuKOZKmlje7fcFR76OWPQGljlD_A1A0rgd2f_1UI28e3pTfiThyxUdFZny3A3iKvz3gEiz2VVvrMONYDNW-aoSd4JSpKFXpBD-XPU04JE64q1dGflDqnnsWjdouy223hcP2xtfX56puef23xtMrF4_QGFtQmbYRC3DVBX2TsWEG_cvPHbViE1kcZz1p32oxGGgQTM667fdVK-TJ80jFWPitzInB5pr6-nbTJ3-6IYHn-BhZnYakJEmAppIt9QphIAhKqheo4Y43StbIYI9vvjLXtjMn6X3mb-6A00dyYcDjdC6hLts-J1UMnz3RrM8VTq56X8TX5p1w5X9AAWdO-tR6yGf7YLORFOqOLqJcCMSmF02jfEh8Hmaa_LjWnvDxbNmp-48Ku5kRkuh_bXxRthGFmaiLWDVVevuk18fqMfYn1gXcGTzf7WMfniMETTA9MPJqDUVnIWQR92RjjatgWGMlzeQEI6NV-PQsfP5UmB8A4RCR8cQmTXaIvnp-pyAIw7uLuu-lPjoaFzGUvAo2j5JDF0Hl85gdsJJjPR1M1-kxXzI2OOihNT0WAha0qimFtr9AzoIGz7fwMQRTCe5yjJtVPK-8u1Rseicqr1-WJk0Ae4iWzAvidevW1AAWSejF7M2Aa3WwZiXdNE9GOlHQu9-VggnCLfHDTdD_UbfEyn-EWulKd9awpzqx21boS_9o8AZzA_V8SeEctJTC4wRyu3IS0obr33pw23lynSDBrAGyR257D5HG_-6NtOluHp0g96w_aERwcdBRuUiz2OoKkgxGnQHs9-kdoVDRWdBrC66MUwIb9CRT33CTKIlioVPdU2Hwl1zqxC5A_VLJ6ZXCooEI6dzx0xgDVCt_4PWwKncMjjp0b3HZTrsZbXF8lPGfmRqRukWz_NF_iyuqnHL09f00E=w654-h872-no
PZpXh3CO1Vc-mu96dNYO6QzeF4Wdf93RSk4z_A6cXczld8qLNISQVX6Vz8-Ja8e66CjHaqSXSv935WgIc7JwUPEX0gEtQnvI3iaEVOqyOJnz9OdeG3Cv-69RViGlLm4UkX0HnqhY5Sl14f-lM3tjEhSPHDsY9-LUI-SHGw689-dxXmIbvn3-hSPxLUdbblRASBWs2GvdKiBlo5HxqReBO_pocvj07fmRHUfS7iGAcDNMI7J2IlzTtlsllzkgjoVItm7b7ZQYuoSQYB3IYiZnPpnP9mkdAyItBw8cp8I2kATUa6AxsZspCdXCuSuf63moit1oPY7XXN9_mUk3kV-3or72awodWud8tagIvWe7ic-xmmmE7JLoMXusiXWN2MhFTBD1XT1s5mb7zouW_aMMmvxfnueZ8-toypjVni9EGjxH0iHZM0WkueE-Bpb5uSb3WfsraZoqhMVXwrJPmSzlieoZOqyNmmBGguGESL6-plVNEx5TapmBeVR8FyTNdQbeBK-MUfiuXcsl8t1ty_vKBoUAaKo-DEoHxQiubSrcwF7TcNvDJY_Wvj0TwPA2U1amj62s1ONkLG39bYz7b4Lsqmw40u6NKK-Aog53Wrcn4oA1aUBnhtDC0csFJFsyBYFDntRZ_3HwTXY8jqvYQK67rYSGyG5Y7J6r0A7y4EM2jT73rMOobEm2ERQNDh_0lOAkV2OPu9fUbeJbg_mHEbuH6MfMu0ixdpSoMJ47WbRvoZ4C9jVi5-E0jpwCKa5CmYJ5nfvIRABwcBuAcUsyyopfOzP6wNBjmxhFe1YA-aVEO_jyXTkneMEAr_tI3CuXcWSUeEOCTOR73Hswk1tNCafZ9jfge8kSNsodH-4FuFT6_tHAaX6UM5Rd_np7_eItwWWvMxcmT3oCTw9GYio-9b-6uoHdMZrUzkY0ByOgpfw65RiNbGcodWOWpUWPT4nvQZzMWiOEJVsZymhUwi3rXmPDrKZuhLdy0oXrH2V5fVhZ1nsaOYoq1KygO6zhqos=w654-h872-no
H5bJk26nKR6HdT96_2P65dviua_Vkq9Ufn5NNkJPun5f-8qIbbRVqrTPzOEqvmvm4LWKjyuK5KoGhQMzBtzrvdLwpdu9t_tjz5RuNIpBeo2C--zdrI9xp8yZ2PRgDeYkLx9O1gtftLfZ2VaBKKjvh3BctMzTzpq4sYQyCg9wxj9Wxg20g31AsZ1FaOPWyuUpjBMHnHchuRmdaCd7epc8cE6Jyf_N6FjD7X2EgeNeBTOYwnUX8ui9tvG0ybGu9jZG1mzByHi8ndfJ2G245P3G9xcVm7eE4e0Dmy1PXE_AMMyJtQwqqeR0r59RiG1eRMawOgpTv0EjobYkqlMRtYj2S0LpoARDzf1Mkh5jAWa5qHg62CBGJP8-kNt_0vQJCw5hZdzk8j5Vesa4-4Nz6ynFqCnLDCcu8UAhJbC-flSHYmA7qyrfNyymBJMI_MIaQLTrTF_mrRLcgCAGbwHdNK1LX-_prl3fi1_RlsY1B_O5eNThRjbvrY1gonYn1cWG1rnc11C9yurtrXbWiCmELXogPLLLV_v6QM7twQpqkoCicjeWkrC_ojo0VVumseyWheUPgxueRP-Hlfqba_TGD6YvLKMLmPtnbep4g92We9Oot5qSw4TOPuajyQ14p1Z94jANn-qcZP1EvHhH-I83T8xVf0x00Z-HrISq_9cFYerQqkGAUy-FRzJ6Mq97ems15uZygRtWlcpIHRHcx7x2rVT2Opw1KKY4sPfnbP9RSF0qhk18yXjAKpJV5cGAFzi7H0ZSrtag6y4BE_Escdsa3ZOiEZ5tRlPA2oeBOh6OALPI_A71Hb9A3w1HGHhJsXqa8FsPvq7zrlOekvhDzgr6nH4IvEQN9SRoFvt0N8q5sWurKZ3lkHGDJVcQik5b3pJkDwWlH8dy_ZB7Gyy3TSer3Y0WgftjU2gfIYJS6v6zq9J4cKNdgldfPS25ku6mCOuhVdvg4Yj4KNaFVavzfLnCDvpIcEck1ZBiI5GCLTGMyDyeMDDJF1YDy0lmrpSilXY=w654-h872-no
Edit: The only similar thread I could find was here, which indicates that other manufacturers use a similar setup:
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
JOHN DEERE HX14 LOT NUMBER 256 (A53084)
JOHN DEERE HX14...
2020 KUBOTA RTV...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
