06 kubota L2800 power steering
   / 06 kubota L2800 power steering #1
NBstunter
new brunswick canada
2006 kubota L2800
on my kubota L2800 there seems to be some lag in the power steering.. when i turn the wheel its really stiff for a second and then lightens up and turns.. its getting really annoying can anyone lead me in the right direction to fix it?
thanks
   / 06 kubota L2800 power steering #2
Check your suction return hose under your right fuel/brake pedal,they tend to crack and leak air then start causeing problems with hydralics on L3400/L2800 models.
Boone
   / 06 kubota L2800 power steering #3
The hose is 1 and 1/2 inch in diameter (give or take) it turns 90* and very roughly about 6 inches long both ways. Pretty easy to change out and cost about $25. I looked for a photo but didn't find one... :(
EDIT: Found one, This is on a newer L3200 model without a FEL but it's close enough...
found it and its in really rough shape... after i replace it will i have to bleed the system? :thumbsup:
   / 06 kubota L2800 power steering #5
No you don't have to do any bleeding. If I remember correctly there was NOT much in the way of oil that leaked out. I forget if helps to have it parked on a small side slope... :confused:
I used duck tape for a short term "fix" but if you have hose clamps and some rubber to wrap around it... that would be better. My dealer had it in stock since it's a common problem with this model...
   / 06 kubota L2800 power steering #6
NBstunter :
If I was you while at dealer I would pick up an extra hydro fluid site glass while your at it.Its un-related to your problem but on those mdls they sometimes leak.Peace of mind to have a back-up ! ($13 bucks) !
Boone
NBstunter :
Boone
already fixed that long ago. i got a metal one from a compressor shop in town. those plastic ones arnt worth even replacing with another plastic one. it was leaking so i took a look around the garage looking for one as i needed the tractor that day and i seen there was one on my compressor and it just happened to be the right size and threads. went to a compressor shop and got another one. i really recommend people to get a metal/glass one. also thanks for the finding my problem.. i was scared i would be blowing $1000 on a steering gearbox rebuild so ive been putting fixing it off. if i knew it was this easy i would of done it long ago. also it fixed problems i wasnt aware i had.. like underpowered and slow moving bucket. thanks guys :thumbsup:
   / 06 kubota L2800 power steering #8
Again, this forum has saved me a lot of grief. This is a night before a big landscape job and when I went to load the tractor it was having this exact same issue. I did a search on here and found this thread. I had already added an extra clamp to this hose thinking it was leaking in the past. After reading this thread I went and checked it again. It looks like new on the outside, but when I reached around to the inside I could feel a big split. No time to go the dealer so I tried the duct tape. Problem solved! ... temporarily...at least I can get through the landscape job tomorrow without fighting the steering. This prolly explains the jerky loader movement that I thought was my imagination last week. Thanks everyone!
   / 06 kubota L2800 power steering #9
Boone
Hey thanks guys you nailed the problem right away, thought i was in for a trip to the shop, a little alcohol and duct tape patched it right up till i get the parts ordered (prayers are answered, even the little ones)
   / 06 kubota L2800 power steering #10
I have this problem, found this thread and got it solved. Thanks so much guys.:drink:
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
