06 Jinma 354XL
   / 06 Jinma 354XL #1
preid0gr
06 Jinma 354XL
Hello, I was out working with my tractor on the 24th moving snow when I put it in reverse, let the clutch out and nothing. Nothing for gear 1 either. Seemed that that the other gear sets were working. I have done some research and it sounds maybe like the 1st/Reverse gear fork. Up to that point the tractor has be solid and runs like a dream, note started at -10 with no issues. From what I have read, I should be able to take the cover off and see the issue but most of the post have been vague in stating what to look for once there. Here is my fear I will get in there, maybe even replace the fork and not have fixed the issue thus causing more damage. Any advice would be greatly appreciated. Thank you.
   / 06 Jinma 354XL #2
Hello. I see you wrote this in December with no replies. I assume you have solved your problem by now. If not and if others with Jinma, FarmPro or others branded Jinmas ever have this issue (I have ran across it twice on the 30hp model) you should stop immediately, take off the top shifter plate and remove all parts of the broken fork, else you will experience broken gear teeth and have to tear down the entire tractor rear end and disassemble the transmission to repair.
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2015 DODGE DURANGO RT (A58018)
2015 DODGE DURANGO...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
