06 BX2350
/ 06 BX2350 #1
ru499
Tuckerton, NJ
Kubota BX25D
I'm looking at a 06 BX2350. It has the FEL and a rear grader blade(LandPride). The tractor looks brand new and has just 52 hrs. What is this worth? Thanks for your help.
/ 06 BX2350 #3
The 50 series BX was a short run due to different customer complaints with the abrupt stop in rveerse being the major complaint. Had one for short time and traded it to get rid of it. Neighbor has one and has had it for several years with no complaints. I checked his and it does have the abrupt stop in reverse but obviously not as big a problem for him as it was for me and many others. It should be discounted over the other series BXs since many people know about the issue(s).
/ 06 BX2350
Thanks to all for the info.
/ 06 BX2350 #5
I have a 2008 BX 2350, FEL, MMM, rear tiller. I have had no problems with it at all. ONLY complaint (not really a complaint) I wish I had gotten the larger motor. This one handles everything I can throw at it and seems to want more. Just wish I had the larger motor for more lifting power on the FEL. I have not had the sudden stop in reverse with this one.
No idea what it is worth. If you get it, I'm sure you will be happy. GOod luck.
APPROX. 40'X40' COMMERCIAL GRADE BUILDING (A62131)
APPROX. 40'X40'...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
INOP/NON-RUNNING 2014 International DuraStar 4300 Cab/Chassis Truck, VIN # 3HAMMAAL2EL786930 (A61165)
INOP/NON-RUNNING...
Topsoil Trommel (A57453)
Topsoil Trommel...
UNUSED RAYTREE RMSG29 HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
