'05 Cub Cadet 1045 (Vibration and Noises)
   / '05 Cub Cadet 1045 (Vibration and Noises) #1
Kingman_1
Philadelphia, Ms
Cub Cadet 1045
\'05 Cub Cadet 1045 (Vibration and Noises)
Need some suggestions from the experienced !!! I purchased a brand new CC 1045 and I'm in love with it. However, when engaging the Blades (PTO) it really seems to bog down the engine even with engine speed running fast. Once engaged, either the belts or the blades seem to vibrate or rattle a bit. Any advise, or am I being a bit over concerned? /forums/images/graemlins/confused.gif
Thanks
   / '05 Cub Cadet 1045 (Vibration and Noises) #2
Re: \'05 Cub Cadet 1045 (Vibration and Noises)
There is a pully set up, like a double pully underneath the machine...these things vibrate and Cub knows about it. Take it to your dealer and have them fix it. We have been putting bushings on as well as a stronger spring. It was just an "overlook" on Cub's part when engineering these machines but is a simple fix. Good luck
Thanks gamble77, I'll do just that and let you know the results.
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
Dry Gel Hydration Unit (A55745)
Dry Gel Hydration...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A52706)
UNUSED RAYTREE...
2023 Chevrolet Tahoe FL SUV (A55853)
2023 Chevrolet...
2008 Chevrolet C7500 Truck, VIN # 1GBM7C1G78F413329 (A54865)
2008 Chevrolet...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
