05 2500 series exhaust *** FIX
   / 05 2500 series exhaust *** FIX #1
aaabelha
'05 Cub Cadet GT2544
Yes.
I too have the dreaded problem of the exhaust outlet burning my lawn. I did see the earlier posts here but I did not think much of it. I always figured I would simply avoid idling in one spot on the lawn while it was running.
Well, I did a ton of yard work with my dump cart in tow over the Memorial day weekend. At various points during this task, I left the engine at idle, running for a few minutes while off the machine working the dumo cart. Brown spots all over the place!
I decided I needed to resolve this.
I bought a 30 degree copper turn fitting pipe, 1& 1/4" in diameter. I cut some relief slots on one end of it, slid it over the tractor exhaust and put a stainless clamp on it. It fits tight, looks kinda cool and redirects the exhaust heat and fumes slightly rearward and up at an angle.
No more burnt grass!
* I used copper because it was soft enough for the average guy like me to work it. I don't have any advanced tools or metal skills.
* I did not sweat-joint the pipe onto the tractor exhaust so as to not void the waranty if I had an engine problem and the dealer wanted to be a jerk about it.
* The copper will eventually turn a patina color but that's just fine with me.
* My grass appreciates not being scorched
I recommend this or something similar to all 2005 and prior 2500 owners.
Yes.
   / 05 2500 series exhaust *** FIX #3
Sounds like a neat mod, but doesn't this blow exhaust towards the operator? /forums/images/graemlins/shocked.gif
Joel
   / 05 2500 series exhaust *** FIX #4
Joel
Actually it stays clear from me because I set it up to pretty much go up and out with only the slightest pitch backwards to clear my add-on front brushguard bumper.
Those of you without the brushguard would be able to pitch it slightly forward or directly sideways, but towards the sky of course.
I could have used a 45 degree turn, but I was afraid of the potential for restricting the flow.
I'll have to post some pictures for you guys!
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
19015 (A55788)
19015 (A55788)
2005 Dodge Grand Caravan Van (A55853)
2005 Dodge Grand...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
