05 2500 series exhaust *** FIX
   / 05 2500 series exhaust *** FIX #1
aaabelha
Bronze Member
'05 Cub Cadet GT2544
Yes.
I too have the dreaded problem of the exhaust outlet burning my lawn. I did see the earlier posts here but I did not think much of it. I always figured I would simply avoid idling in one spot on the lawn while it was running.
Well, I did a ton of yard work with my dump cart in tow over the Memorial day weekend. At various points during this task, I left the engine at idle, running for a few minutes while off the machine working the dumo cart. Brown spots all over the place!
I decided I needed to resolve this.
I bought a 30 degree copper turn fitting pipe, 1& 1/4" in diameter. I cut some relief slots on one end of it, slid it over the tractor exhaust and put a stainless clamp on it. It fits tight, looks kinda cool and redirects the exhaust heat and fumes slightly rearward and up at an angle.
No more burnt grass!
* I used copper because it was soft enough for the average guy like me to work it. I don't have any advanced tools or metal skills.
* I did not sweat-joint the pipe onto the tractor exhaust so as to not void the waranty if I had an engine problem and the dealer wanted to be a jerk about it.
* The copper will eventually turn a patina color but that's just fine with me.
* My grass appreciates not being scorched
I recommend this or something similar to all 2005 and prior 2500 owners.
Yes.
   / 05 2500 series exhaust *** FIX #3
Sounds like a neat mod, but doesn't this blow exhaust towards the operator? /forums/images/graemlins/shocked.gif
Joel
   / 05 2500 series exhaust *** FIX #4
Joel
Actually it stays clear from me because I set it up to pretty much go up and out with only the slightest pitch backwards to clear my add-on front brushguard bumper.
Those of you without the brushguard would be able to pitch it slightly forward or directly sideways, but towards the sky of course.
I could have used a 45 degree turn, but I was afraid of the potential for restricting the flow.
I'll have to post some pictures for you guys!
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53473)
Kubota SVL65-2...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A51692)
2006 Ford F-550...
1996 Trailmobile 53 ft. Dry Van Trailer (A53117)
1996 Trailmobile...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
