'04 TC40D quits running
   / '04 TC40D quits running #1
davidtractor
My '04 TC40D will be running fine and then will just cut off. It will start right back up and will run about 10 minutes and then cuts off again. Several months ago, it began to act like it wanted to cut off every now and then but it just started cutting off in the last several weeks. It only has 575 hours and I purchased it new.
   / '04 TC40D quits running #2
If it just shut's off then it sound's like a relay or a loose wire or a dirty conection to me .If the power falls off before it dies it sound's like a fuel filter . Some of the other members here might have a better idea where to look first.
   / '04 TC40D quits running #3
I agree with FULLPULL. I'm thinking more along the lines of a clogged fuel filter or some other delivery problem rather than electrical since it will start back up and run a little while. I'd look at the fuel filter and change it as a first step.
I'm getting a fuel filter and will start with that. Will let you know!
   / '04 TC40D quits running #5
The fuel taps on the bottom of the tank have a finger sized filter in them sticks up in the tank.. if you look at it wrong it can get plugged up... Been there.. done that..
Soundguy
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
ECHO PE-225 GAS WEED EATER (A51248)
ECHO PE-225 GAS...
