04 f250 ford 6.0 PSD throttle surge issue
   / 04 f250 ford 6.0 PSD throttle surge issue #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
At work we have two of these truck.
Just got a call from the jobsite that one of them is doing an odd throttle/rpm surge.
it can be setting there idling, and all of a sudden 'takes off', then will act like normal.
No pattern, intermittant.
Any ideas?
I know it uses a HPOP and no 'normal' IP, etc.
Since it has a turbo.. do these have a boost sensor and pedel sensor to figure fuel dump?
I'm heading out in a bit with a superchips code reader that is setup for 04 6.0PSD to see what I can find. Any tips or guesses will be appreciated.
   / 04 f250 ford 6.0 PSD throttle surge issue #2
Mine was doing that and had to replace the ICP sensor.
interesting, thanks. a code to watch out for.
   / 04 f250 ford 6.0 PSD throttle surge issue #4
Is it a high rpm or a high idle.
It goes to 2-3k real fast, but returns quick.
Ok, code reader confirms p2287. Icp
Now where is it? ;)
Also code p0275 came up. Cyl5 contribution balance. Sounds lil a issue, but the icp sounds like 'the' issue
   / 04 f250 ford 6.0 PSD throttle surge issue #6
Well if it's built prior to 9-29-04 , it will be on the rear of the engine under the turbo, if built after that date it will be on the top of the right side valve cover in the front.
Yup.. Hard spot :)
   / 04 f250 ford 6.0 PSD throttle surge issue #8
Wait till you price the sensor from ford. :)
Also if it is leaking oil into the harness make sure you clean the harness good or buy the replacement pigtail.
like 250$ sensor. :)
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
