“Disappearing” Lynch Pins
   / “Disappearing” Lynch Pins #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
I am inexperienced but it seems to me a lynch pin should not pop out if installed correctly. Two guys were running tractors at deer camp this weekend and had a spreader and rototiller come off the 3PH. One swears he had the lynch pin installed and it must have broken off....that seems unlikely too.
Seems more likely it was not snapped closed
Opinions?
   / “Disappearing” Lynch Pins #2
I lost one with the rototiller once. Luckily I caught it in time as the pin was half way out of its position.
It's like these things always find a way to either pop off and be lost forever or to smack your fingers really bad, preferably with cold hands.
I used to have lynch pins on the backhoe bucket as well but of course, I was constantly losing those. Now I put a piece of wire through the holes and bend the ends so it doesn't come off.
   / “Disappearing” Lynch Pins #3
I have lynch pins holding the spindles in on the caster wheels on my mower, brush cutter, and snow plow. I lose several a year on the brush cutter. So much so, that I buy a half dozen and keep them in my toolbox on the trailer that I haul the machine on. If doesn't take much for a stick to grab them and pop them open, then it's just a matter of time before it's gone.
   / “Disappearing” Lynch Pins #4
I’ve lost a bunch of them especially in my backhoe bucket pin. I was bolting it but one method I discovered by accident that hasn’t failed me yet is heavy gauge wire bent through it and you can undo it by hand. I bought a heavy duty lunch pin for the backhoe bucket pin but it didn’t make it past the first job before it was lost to.
   / “Disappearing” Lynch Pins #5
   / “Disappearing” Lynch Pins #7
They get snagged by brush, unlatch, and fall out.
I have replaced some with large cotter pins.
   / “Disappearing” Lynch Pins #8
I guess I have been lucky, never had one come off, done a good bit of farming and tractoring thru the years.
   / “Disappearing” Lynch Pins #9
I have lost a few over the years also.
   / “Disappearing” Lynch Pins #10
Same here with loosing lynch pins, so I finally put some on the drill press and added a hole for a hitch pin, problem fixed.
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
2018 RoGator 1100C (A55314)
2018 RoGator 1100C...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2007 International 4300 (A53314)
2007 International...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
