Farmtrac...is it a Ford??
/ Farmtrac...is it a Ford?? #1
Big_Cajun
South Central Louisiana
MF 1130
Just wanting some hard evidence that these tractors were/are made in the old Ford plants.
BC
/ Farmtrac...is it a Ford?? #2
I don't think so. I had a dealer tell me the 270DTC had a Ford engine in it. I knew that was not true, so I went with a Kubota.
/ Farmtrac...is it a Ford?? #3
the compacts are Daedong and Mitsubishi powered and made by LG in Korea. Not sure about the big tractors??:)
John
/ Farmtrac...is it a Ford?? #4
The 5 and 6 series are mainly of the older Ford design. I think there's one model in the 5 series (maybe 2) that are the Long tractor with the new name. The others are Ford types. The 675 has a Perkins engine and 665 and 675 both have Carraro from the clutch back. They have 12 speed fwd and rev Gear shuttle + flat platform.
Here's a copy and paste from the Farmtrac web site:
Farmtrac now offers replacement engines for most of the Ford
3000 and 4000 Series tractors originally equipped with 175,
192, or 201 cubic inch engines. If you own an older Ford tractor
that is in need of a complete engine overhaul, contact your
local Farmtrac dealer to learn more about our new, emission-
compliant replacement engines.
For just a little more than the cost of an overhaul on your
current engine, and for much less than replacing with an engine
purchased from New Holland, the Farmtrac Engine Kit features
the SAME reliable engine that comes on new Farmtrac tractors
today and that had been factory installed in the past on new
Ford tractors. Engine kit includes new fuel injection equipment,
water pump, fan belt pulley, starter and alternator.
Here's a link to Escorts afri:Escorts agri..
And another:Escort agri products..
Forgot to mention. Even with the perkins engine mine still uses Ford air filters and many other Ford parts. Just from my memory (and it isn't as good as it use to be) the Farmtrac looks a lot like a Ford tractor that was being sold in my area that came out of Canada in the 70's. They had the head lights in the grill and just looked a little different(fenders). Those tractors are still running today. They were sold at a lesser price than American Ford tractors then. Seemed to hold up just as well.
Back when I bought my Farmtrac 80 (now 675) my dealer told me they were made in India in the old Ford tractor plant. Said you could throw a rock over to the JD plant from it. He also said Escorts had bought the patent of the Ford tractors that were no longer being made.
LG at one time was in this deal too. Haven't kept up with the compact line so I won't comment on them. The 7 series is made by SAME for Farmtrac. I like the looks of those but a little to much $$$$$$ for me right now.
/ Farmtrac...is it a Ford?? #5
FarmTrac was the Ford Licensee for India. After Fiat no longer needed FarmTrac,Escorts bought them out,along with the aging designs. The 4 & 5 series are pure Ford/Farmtracs,the smaller 6 series is a cross breed it looks like.
Valley Tractor Sales Here is a bit of info.....
/ Farmtrac...is it a Ford?? #6
The FarmTrac 545 and 555 are your older Ford's, the few things that have been changed are the brakes, injection pump (to meet epa standards), and they went to true hydrostatic steering. Other than that the motor, trans. and rear end is a dead match.
/ Farmtrac...is it a Ford?? #7
I had no idea that farmtrac was making repop engines for the older fords... pretty neat..
Soundguy
/ Farmtrac...is it a Ford?? #8
I've seens ads from a local dealer advertising that for about a year. The very early 3 cyl. Farmtrac utilities that I saw still had "NH" cast in the engine block, they now have Farmtrac or Escorts, can't remember which, it's been awhile since I've looked at one. Interestingly enough, New Holland built a new plant in India after selling the old one to Escorts, and manufactures, or at least did thru 1999, the old style Ford-NH tractor as well, but with the Ford name and the NH emblem.
/ Farmtrac...is it a Ford?? #9
Is it hard to get parts or repair work done on these? Do ford parts interchange? Will there be support for the farmtracs down the road?
/ Farmtrac...is it a Ford?? #10
start a new thread.. this ones 3ys old !
soundguy
/ Farmtrac...is it a Ford?? #11
I would like to sell our 2006 farmtac 545 front loader. Great shape. But it is to bog for our farm. Mainly just sits in the pole barn. Less than a 100 hours on the tractor. Any suggestion on a smlller model, We only have 40 acres to bush hog. Plus it has a front loader. That means toy have to have your eyes on a coiple of things. A lot of inconvenience. Garry aka cavedog69
/ Farmtrac...is it a Ford?? #12
try a calssified add. probably get more coverage.
good luck
soundguy
/ Farmtrac...is it a Ford?? #13
i have a 545dtc ,it has tranny problem,stripped teeth off 3 gear,has any one had one apart and how costly is it ?
/ Farmtrac...is it a Ford?? #14
try starting a new post without burrying your question in an old one.. it will likely get more views.
soundguy
/ Farmtrac...is it a Ford?? #17
Farmtrac isn't a ford,this tractor it has many many prolem especialy hydrolc systeam.
/ Farmtrac...is it a Ford?? #18
i have a 555 DTC n its pretty awesome... very stable bush hoggin' on hills, strong as an ox
/ Farmtrac...is it a Ford?? #19
The Farmtrac model 270 is made by Kioti tractor, engine and all. Very, Very, Very good machines. 10 ti,es better than Kubota and their aluminum tractors!
/ Farmtrac...is it a Ford?? #20
My particular Farmtrac IS the same as a Ford/New Holland. (It's a 545) There are different Farmtrac tractors made by different companies and all wearing the Farmtrac badge.
How do I know? The parts that I ordered for mine came from India and they have FORD/New Holland Part numbers. Farmtrac has disguised the part numbers in their parts breakdown (They us a number that begins with ESLxxxxxx) BUt if you dig around enough you can find the same old part made for Ford or New Holland tractors. The valve rockers for mine clearly said Ford 3600 on them.
I wish I could tell what year mine was built! It is somewhere between an 06 and an 09 I think. Not really sure.
7102 (A61567)
7102 (A61567)
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
ATS T460 Mini Skid Steer (A64047)
ATS T460 Mini Skid...
60� Tine Rake (A64047)
60� Tine Rake...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59911)
2005 KENWORTH T800...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
