Mowing JD990 + NH 451 sicklebar mower
   / JD990 + NH 451 sicklebar mower #1
DPic105
Member
JD 990
Member
Posts: 31 JD 990 + NH 451
Need help!
Does anyone know how to hook up a NH 451 sicklebar mower to a JD 990 tractor??
I tried to do it today and found that the JD's three point hitch is too narrow at the top. I finally just used my top link to the frame of the NH, bypassing their set up, but also making it impossible to raise the mower.
DPic105
View Public Profile
Send a private message to DPic105
Find More Posts by DPic105
Add DPic105 to Your Buddy List
   / JD990 + NH 451 sicklebar mower #2
I also have a NH 451 mower as you described. On my JD 4500 I chained the top links together and just picked it up with a quick hitch. It worked ok, you just don't have the flexibility of the sickle going up and down as you raise and lower the mower. I am working on a solution to add a hyd. cylinder to do that.
John
   / JD990 + NH 451 sicklebar mower #3
John
Tried hooking up 451 sickle to my 3320 also, found your posts and was wondering if you found options to lift bar and attaching to top link ? Thank you
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
UNUSED FUTURE 30" PALLET FORKS (A57193)
UNUSED FUTURE 30"...
2019 Hustler 60in Zero Turn Commercial Mower (A55851)
2019 Hustler 60in...
Texaco Vintage Decorative Fuel Pump (A55853)
Texaco Vintage...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
Lounging Mermaid Statue (A55853)
Lounging Mermaid...
