G3038h
Tarnold
Ellijay ga
Ls 3038h, ford 1900
G3038h. Dealer can’t get ls to clarify! I’ve broken the rod that makes the F/R pedals to move the tractor. It shows as item 15 on the HST CONTROL parts page . On mine it is a 2 piece rod with ball joints on each end with a turn buckle connector joining the 2 rods allowing for forward/reverse adjustment. My turnbuckle is only 2 inches long. What the referenced page shows a one piece (maybe round or hex) rod with ball joints but could possibly be 15 inches long. Afraid to order cause if wrong it’s mine for about $150. So, does anybody know if this is replacement for what I have?
What broke? The joint? I replaced different version of that setup on my LS using Heim joints. On set the from Amazon and the the ones on the Backhoe from https://midwestcontrol.com/shop/
You just need to know the thread sizes on each end and male or female.
Other places have them cheap as well, like Summit Racing.
Mine has the 10" or so hex turnbuckle like shown in you #15, but a $10 set of 4 from Amazon took care of the issue for last couple of years with spares. Just have to adjust after installing, like you would with the factory parts. I measure everything and found items that match. Bit tedious but cheap.
/ G3038h
Op here. It’s the cast part of the ball joint where the threaded rod screws into right about at the 90 degree I know the rod is m8 1.25.
Like this for example
You can also find sets with both left and right hand threaded joints.
Amazon
A little measuring and searching, and have spares for less money. If you can find them the next time :rolleyes:
/ G3038h
Op again. Found an item on Amazon that should work. T rod with ball joints on either end. Only $10 so not out anything.
I know this rod controls the forward back motion and should be adjusted for equal pedal travel. But, could it be set to allow for more forward/less backward speed with out hurting anything?
You will have neutral (centered) switch that has to be satisfied at rest. There is some adjustment on that and you can play a bit. Big thing the rod and turnbuckle need is to eliminate play on the pedals and stop at center. If you are out to far the tractor will want to creep with no input.
Only one input to the HST rotates one direction for forward and the other way for backwards travel. Not complicated just tight space and under everything.
Had a very similar joint for steering come apart on my Kubota zero turn lawnmower, managed to put it back together and put a rubber band on to help hold it together to finish mowing the lawn. Took a picture of it to my local Kubota dealer and he laughed when he saw the rubber band holding it together. He ordered the replacement parts and I installed them, I was amazed to find out the part cost less than $5 , that was about 5 years ago so the part probably costs quite a bit more today.
Still under $5 today but the LS part is the whole assy, made up of $10 worth of parts for a discounted $120.
Had rod end and stud joint on my backhoe valve fail. Can only replace valve assy for >$1200. Found heim joint (my preference) to replace old parts at $22 for 12. Plenty of spares now and have used a couple more.
Plenty of aftermarket parts on my Kubota as well, it's not like they make all the pieces from nothing. They order from their suppliers.....
/ G3038h
Op again. My Amazon part came in this am. It’s a tyerod with ball joints on either end 280mm length is just a tad too long . 8mmx1.25 threads. Had to grind off 2 threads on each end of the rod to get any adjustment, should have been more, but for now it’s back together. Need to take floorboards off to get at it. WARNING do not have any young kids around when you try to remove and reinstall the inside nut on the front ball joint. Less than $11 dollars, from LS 116+35 shipping plus tax.
The front likes to come loose, hope you used some thread locker.... 🤔
For a $140 I'll do some grinding and cutting
