Not sure yet, I was trying to look up the parts diagram on messicks site but their site isn't working for me.Is there an o ring or some other kind of seal in there.
Thanks, now I'm wondering if it might be leaking at the o ring side? Quick look seemed like it was leaking more from the nut.Did some research on this, and that line goes to a 9/16 connector that has a rubber o-ring. However, it looks like you leak is on the flanged side.
I would first get two box wrenches and tighten the heck out of it.
K2561-36620
Going to pull the tire tomorrow and get a better look.
Going to have to wait till the crows foot comes in on Fri, cause I can't get the other end off with my wrench.Now that I see this is going around the PTO and 3PT area, I suspect it the line may have been pushed/bent and its slightly off center now to the flare fitting. Or the flare fitting is scored and leaking.
To fix first try to loosen one or both ends then reposition the flare connection to be properly seated. If that doesnt work, I would remove the line, and clean/polish the flare ends, and put it back with a good flare Male-Female connection- you should be able to turn the JIC fittings by hand when installing (limited to no tension on the fitting or nut on the flare).
