WM75Guy
Elite Member
I run a 6' Land Pride tiller on my TC40DA with 33 HP PTO. Haven't had any problems.
Considering I did this for a living for many years and I had 3 tillers working, including a 6' and a 7' all on many different tractors, I think I know a thing or two about tillage with a tiller.Help me out. How do you work “tine speed” into the equation? And how does it make a huge difference?
A tiller should be run at WOT like a mower. I’m trying to understand how “tine speed” figures in. And how would someone determine tine speed and use that to guide their decision about proper tiller?
I think this is an example of TBN over-complicating an issue. Unless there’s something wrong or badly designed, the typical tractor should handle the smallest tiller that covers the rear tire tracks. It really is that simple.
An old hp rule that a then old timer, taught me (a now old timer at 65) was roughly 6 engine HP for every foot of implement width. Or 4 PTO HP for every foot of implement width. Based on either of this rule, you are safe for a 6’ tiller.I’d need a six footer to cover my tracks, but that width requires just a bit more PTO HP than I have. That, coupled with our heavy clay soil, has me worried that it might be too much for the JD. A five footer covers half my wheel width while not overtaxing the tractor, which I could live with
I'll second this. I run a 60" King Kutter behind my JD 4100 in clay soils. Previously worked soils, it does just fine. If I get in it too early, when it's a bit too wet, it'll lug a bit, but can control that with the depth. In soils that hasn't been touched before, I need to start with shallow pass and increase depth on successive passes. Is it too big for it? Probably, but have been using it for over 10 and haven't blown up anything yet.I don't think a 6' tiller would be a problem at all. I use a 60" behind my JD 2520, which is about 25hp, and it has plenty of power. I actually for a hobby till peoples' gardens through the area with it. Heck, I'd think my 2520 could handle a 72", power-wise. You'll thank yourself so, so much in the future if you but a tiller that at least is wider than your tractor's tire track width.
I run a 6’ county line tiller behind a 40 horse Foton tractor. I can till full depth on anything except really wet ground. I run in low #1 and it does great! If it’s muddy it will bog me down unless I pull it shallower. Dry ground it is a ground eating machine!All the used six footers I’ve looked at over the winter had been used hard and resembled pix of Russian military equipment after a drone strike. Yesterday I looked at a 60” Kuhn EL43-150. Two years old, minimal use, and impeccably maintained. It can easily be offset so I bought it. From the looks of it it’s going to last my lifetime.
I never work wet soil so it’ll be a while before it sees use, and I’ll preface it with a heavy c-tine cultivator in a cross-hatch pattern. Any small stones uncovered will be used to line drainage ditches, and any large boulders will be harvested with my excavator for stone walls.
Some times there is simply no choice but to till wet ground. It is what it is.I keep seeing people talking about tiller performance and "wet ground". In what scenario does ANYONE till when the soil is wet? No matter how well or poorly a tiller operates, the resulting ground is going to be horrible for planting anything if it was wet when tilled. I mean... unless you all are tilling sand or something. Trying to plant in hard clumpy soil after being tilled wet is the worst.
I fail to see it. You can't plant when the soil is that saturated and the resulting ground will be very hard if you wait for it to dry. Seeds won't even come through that most of the time. Maybe you have different soils? If the soil is we it doesn't get tilled here.Some times there is simply no choice but to till wet ground. It is what it is.
We went from a severe drought to a completely water saturated soil in the entire country within 3 to 4 months of nearly continuous rain.
We and lots of other people in country have been waiting and waiting for things to dry out but it's a very slow process and we need to get vegetables and what not planted when it's the correct time.
Last week I just plowed a plot on the land to plant vegetables. This was on the other propriety where it's an heavy clay soil. This have been drying fairly well and plan on tilling it this week.
Here at home, it's a dark sandy soil. I had to till it when it was wet and it's already half way planted with various vegetables.
