M7040 Weak, choppy hydraulics
/ M7040 Weak, choppy hydraulics #1
berrycw
Middle LaHave, Canada
Kubota M7040, Kubota B3300U
Had the hydraulic fluid changed 100 hours ago on my M7040 (2011 model), 3100 hours. Used Kubota filters and fluid. The hydraulic pressure relief value by the rear remotes was adjusted to bring up the pressure a bit as it was noticed that the hydraulic flow seemed a bit weak.
Have not done a lot of work with the tractor over the winter just plowing snow on the farm every couple of weeks. Tractor worked ok up until now. Last used a couple of weeks ago. Now the hydraulics have no power. Pump is whining a bit. Power steering has no power or is very choppy. Fluid is clear, and full. No signs of any leaks.
Dealer mechanic thinks either a clogged filter, or the hydraulic pump has bit the dust. Any other suggestions?
/ M7040 Weak, choppy hydraulics #2
Suggest you post this question on OrangeTractorTalks.com, Service, Repair & Maintenance forum.
/ M7040 Weak, choppy hydraulics #3
I've owned a ''11 M7040 since 2012. My guess is debris is in hyd relief valve seating area or a hyd control valve is not in neutral position. I suggest checking hyd pressure with a gauge.
Move 3pt control lever forward an inch. If that helps restore hyd pressure then 3pt feedback rod needs adjusting.
2011 Tri Axle Frac Blender Trailer (A64194)
2011 Tri Axle Frac...
Land Hero Mini Skidsteer (A66408)
Land Hero Mini...
2015 Ford E-350 Shuttle Bus (A64556)
2015 Ford E-350...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
(2) New 26X9-14.5 severe duty batwing tires on 5-lug batwing rims, Coal Valley, IL (A65640)
(2) New 26X9-14.5...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
