Cummins powered Ford
/ Cummins powered Ford #21
The Cummins B engine is the only medium-duty diesel engine used in pickups, Ford and Chevy diesels are light-duty engines.
The Cummins B engine is designed for use in garbage trucks, which is considered extreme-duty use. So it's designed much differently than the others built for rapid throttle response.
That Cummins is a great engine. I have two of them but both are in older trucks. If you want to read some horror stories go onto some of the Facebook pages for the new 2500 and 3500 Rams. The electronics problems are killing them and apparently the dealers can't fix them. Also, after so many years of building engines with solid lifters a couple years ago Cummins decided to go to hydraulic lifters - and those are failing at an alarming rate, destroying the engine.
Why I will NOT be buying a new one until they get all their problems figured out!
/ Cummins powered Ford #22
That's a shame IMO. The B engine used to be a solid 300,000 mile engine in dump trucks.
/ Cummins powered Ford #23
Theres a lot of Fords running around with Cummins in them, but very few Rams with Powerstrokes lol
Personally I like a GM in my Ford. LOL
And no, it doesn't leak all that oil. It actually doesn't even leave spots on the ground. It's been Krown oil sprayed all it's life for rust prevention and I just haven't washed it.
/ Cummins powered Ford #25
Ford, too. Pretty sure GM still using pushrod with solid lifters on the LP5, but I just read pages of problems they are having with oil starvation.
I agree hydraulic lifters is a step backwards, but they think it’s a step forward.
Overall, I can’t believe in 2026, none of them really seem to be able to get it right, and when they do, they move onto something else for either HP wars or improved fuel economy.
/ Cummins powered Ford #26
I think the problem is the suppliers they all source their parts from, because every single manufacturer is having cam and lifter issues.
/ Cummins powered Ford #27
I gotta throw the BS flag on that. The ST tires are rated for 65MPH maximum continuous speed.:giggle:
You know you can buy ST tires with 80+mph speed ratings?
I don't drive that fast towing so I have tires rated for 75mph on my gooseneck trailer and 68mph on my dump trailer (it doesn't take trips on the highway anyways).
/ Cummins powered Ford #28
This is an interesting video on the new gen 6 Cummins. They have a used engine they are tearing down to see the differences of the new one. Towards the end they weigh the different blocks and they are close except the much lighter gen 5 CGI block. Also, the older ones were made in Brazil, gen 5 in Mexico, and the new gen 6 is from China.
/ Cummins powered Ford #29
The 6.7L Cummins is also used in Ag tractors.
Pretty much says it all.
/ Cummins powered Ford #30
I put the "killer dowel pin" tab on my 97' 5.9. I had 350k on it when I sold it after loosing 5th gear again. As long as I ran about 1/2 qt low on the oil, it used very little.
There used to be someone on the TDR that had put an 8.3 in a Ford. He had heavily modified the frame to hold that weight.
/ Cummins powered Ford #31
Why Stroke it when you can Ram it?
A good friend of mine has a deleted 3500 dually Ram. The recirculation and clogged exhausts kill the engine and mileage. Have you ever seen inside one of the cats on those trucks - the honeycomb mesh is so fine I doubt you could even breathe through one of them. Now he gets a real 21+ mpg on highway unladen.
The earliest Cummins engines no doubt were pulled off of their assembly line of engines earmarked for class 6 and 7 trucks. Later engines I think had lighter duty connecting rods, as the pro engine builders specify the early 5.9 rods in their 1500-3000hp builds.
CP3 to CP4 pump change is a debacle. Best thing for newer engines is to let them breathe, but not sure how it’s done with no-tamper features built in nowadays.
PS Tractor pictured in thread is a competition pulling tractor by looks of driver roll-cage.
/ Cummins powered Ford #32
I had a 210HP 5.9L Cummins in a JCB farm tractor. Was talking to tractor tech about it. He told me they tore very few of them down.
The Sisus are also an excellent engine. We have a huge AGCO dealership nearby and one of their more experienced tech's said it was rare to see a Sisu torn down under 15,000 hours
/ Cummins powered Ford #33
I am with you man! A Detroit 6V92 is a great engine will running a long time with sweet care. Easy starting in cold weather.
2021 Bobcat UV34 4x4 Gas Utility Cart (A61572)
2021 Bobcat UV34...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64280)
KNOW BEFORE YOU...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2017 Ford F-250...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
EZ Trail 3400 (A63688)
RoGator and Terragator Manuals (A63117)
RoGator and...
Here are some similar links:
