Transmission/Hydraulic Oil
/ Transmission/Hydraulic Oil #1
Fikey
NH Workmaster 75
Is there any factual reason to use NH brand (134) oil as opposed to a universal hydraulic oil?
/ Transmission/Hydraulic Oil #2
Opinions vary, but factually these oils are not manufactured to universal standards like API engine oils are. They may state an ISO viscosity rating, and claim compatibility with various OEM fluids.
My favorite example was a post here on TBN years ago that showed the front lable of a UTF (non OEM) fluid claiming compatibility with all modern tractor hydraulics and transmissions... The back lable said it was not to be used in machines manufactured after 1972.
/ Transmission/Hydraulic Oil #3
Maybe warranty, but even then I don’t think it’s strictly necessary.
As long as it meets the spec of NH134D you’re good. You wouldn’t go to a car dealer every time you needed a jug of engine oil I assume, or back to the dealer for tubes of grease :)
Most manuals will have a page on service for lube specifications, usually that states “When proprietary product is not available, use one that meets (fluid specification.)”
I work on compact tractors for a living. I’ve yet to see or hear of any sort of hydraulic or hydrostatic damage from using equivalent aftermarket fluids.
(NEVER PUT 303 IN A NEWER TRACTOR-ITS NOT GOOD FOR WET BRAKES OR CLUTCHES.)
80% of hydraulic or hydrostatic failures I see are from lack of maintenance or abuse. Especially in power shift transmissions, contaminated fluid is real bad for them.
/ Transmission/Hydraulic Oil #4
It’s just me, but “compatible with” is a very misunderstood term. I take it to mean “This is a product that will not produce an adverse reaction when mixed/used in the aforementioned.”
Meeting the specifications of a fluid should result in something that’s chemically indistingushable in components and performance.
/ Transmission/Hydraulic Oil #5
Does the machine have wet brakes,clutch or hydro drive? If it does use the NH fluid specifically for it. $300 in fluid is alot cheaper than replacing parts and the fluid with the correct stuff.
Hydraulic fluid isn't like motor oil with the API 3rd party testing. This means any oil manufacturer can state it meets any spec and there's no one testing that it actually does.
/ Transmission/Hydraulic Oil #6
With a gear drive tractor, I use any GOOD quality trans oil, BUT with a hydro trans I stick pretty close to tractor brand fluid.
SR
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
DEUTZ ENGINE (A63569)
2022 EZ-GO ELITE...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
RAIN FLO 1200 WATER WHEEL TRANSPLANTER (A63291)
RAIN FLO 1200...
