PT 422 power Trac to dingo quick attach
/ PT 422 power Trac to dingo quick attach #1
Copat
Power Trac PT422
Does anyone make a quick attach power Trac to dingo universal mini skid attachment? Would be awesome/easier to get implements locally if I could run mini skid attachments. There are a lot for sale in my area
/ PT 422 power Trac to dingo quick attach #2
Most people make their own or have a local fabricator weld together a PT blank plate to a (name your favorite) industry standard quick attach adapter.
Thank you. I will likely go that route as the mini skid attachments are much more readily available. Is it as simple as getting a female quick attach plates from power Trac and welding it to a dingo plate?
/ PT 422 power Trac to dingo quick attach #4
You probably need to space the dingo plate out enough to allow the locks to function. Bear in mind you need the Dingo side "male" plate, not the one that is on the attachment, right?
Look for a "Toro-Dingo CII (Universal Mini Plate)", should be about 22.75x9.25". I don't know the pin lock spacing, but you will need the locking pin assemblies as well.
All the best,
Peter
2022 EZ-GO ELITE...
Allis Chalmers WD45 (A66285)
Allis Chalmers...
Caterpillar 446B Backhoe (A66285)
Caterpillar 446B...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
