Thoughts on 3pt log splitters?
/ Thoughts on 3pt log splitters? #121
You better try again, you obviously are doing it wrong!
I've posted many times on how to do it right, with pictures, so go check them out. lol
SR
I've seen your pictures, doesn't work well enough with my equipment to to make it worthwhile.
Your setup seems to work well enough for you, I just found a more efficient way using the equipment I have.
Sent from my SM-S921U using TractorByNet mobile app
/ Thoughts on 3pt log splitters? #122
I've split all my firewood with a 3PH splitter for more than 25 years. It works, BUT I'm 86 years young, and lately, it's been getting more challenging.
This year I've made some changes that are keeping me in the game. The key for me is to never (well, hardly ever) have to stoop or bend to the ground. Also, to minimize muscle work. Here's what I've done:
Spend some money: I already had a tractor with forks. I added (1) Full Boar 35 ton stand-alone splitter ($3.2K) with 600-pound log lifter, outfeed table, and 4- and 6-way blades, (2) Chinese mini-excavator ($18K) to service the log pile (among other things), and (3) 29 IBC totes ($15-$30 each) to hold the splits. It works like this:
The tractor pulls the splitter to the log pile and positions it about 30 feet behind one end. It gets an empty IBC tote and places it next to the splitter outfeed table. I then position my mini excavator halfway between the log pile and the splitter. This is the process:
The mini excavator picks a log from the pile and rotates it 180 degrees to the splitter. While it holds the log at a convenient height, I (or a helper) cut the rounds, which drop to the ground near the log lift. Cut rounds are rolled to the log lift; they are moved with a hookaroon, so there is no bending or stooping. The log lift loads the rounds to the splitter. The splitter pushes the splits to the outfeed table. They are easily tossed (not stacked!) from the table to the nearby IBC tote. (No bending or stooping, and individual sticks are very light.) When the tote becomes full, the tractor moves the tote to covered storage and brings an empty. Rinse and repeat.
The process easily accommodates 1-3 workers.
When I need a new load of firewood, the tractor (forks) replaces an empty tote with a full one under covered entrance to the house.
This setup won't fly for a lot of folks on a budget, but it's easy, safe, and fast, and in winter it reduces my electric bill by several hundred dollars per month.
/ Thoughts on 3pt log splitters? #123
I wouldn't run my tractor to run a log splitter. Sure the tractor is designed for work but I would rather run a low cost stand-alone splitter and save the hours on the tractor. 1000-1500 gets you a real nice stand alone splitter that you don't have to take off and on. Get one that converts to vertical as I feel this is the best position especially for very big logs. Used are even cheaper and you have a ball receiver to cart it around.
Here is me doing nice size red oak....
Nice video -- I watched it twice! You reminded me that big rounds are kind of PITA. I could never do what you were doing. My biggest rounds are maybe 24 inches diameter. I had to use my tractor to tip over an oak round that size in order to roll it!
BTW, my tractor doesn't have extendable links on the 3-pt, so rear implement swapping is not easy. My workaround was to park the splitter on a sturdy bench and give it 10 ft. hydraulic hoses. To use it, I just parked the tractor nearby and plugged in.
/ Thoughts on 3pt log splitters? #124
Didn't read all the responses so this has likely been covered. I don't use a three point splitter because if you do the math most small tractors don't have the hydraulic flow to run one efficiently. I also want my tractor available for other log handling tasks. Finally and most importantly, I'm not running up hours and maintenance on a 30k piece of equipment when a 1k piece of equipment can do the job more effectively.
/ Thoughts on 3pt log splitters? #125
Yep, that's the consensus.
/ Thoughts on 3pt log splitters? #126
Yeah , that looked like a lot of work!! I am glad I don't get rounds that sized.
/ Thoughts on 3pt log splitters? #128
I like my 3 pt splitter w/PTO pump. Tractor runs at 1200 rpm, ram doesn't move very fast, but then again I'm 71 and I don't move very fast either. If log is too heavy for me to lift, I just drop the splitter to the ground and roll it on, then lift splitter back to the height I want.
/ Thoughts on 3pt log splitters? #129
years ago, I did the bobcat and tractor splitters, I went back to
the gas-powered splitter, this is the one I built with the new motor
has electric start , lights, and i use a 2500 lbs winch to pick up the
big ones to split or drag them to me . i didn't like that the machines was
tied to the splitters .
/ Thoughts on 3pt log splitters? #130
I dont agree…..i love my 3 point.
I am with you on that.
I would imagine people with lower output capacity hydraulic systems could get frustrated with a slow ram speed, but it really depends on your tractor. I run my 3pt splitter behind a 77hp(65pto) tractor with 23gpm pump. I can let the tractor idle and the ram is fast/powerful enough.
My point is, don't blame a 3pt splitter for the shortcomings of your tractor choice!
David from Jax
/ Thoughts on 3pt log splitters? #131
David from Jax
23 gpm is a sizable output. My 52hp tractor is only making 9.5 gpm
/ Thoughts on 3pt log splitters? #133
My 53hp tractor is making 16gpm at the remotes.
My 3 point splitter has a 20 gpm pto pump and we love our 3 point splitter!
SR
/ Thoughts on 3pt log splitters? #135
35 hp Mahindra runs a big hydraulic cylinder on a beam with blade.
Got $300 in it, but I only have a small fire pit .
/ Thoughts on 3pt log splitters? #136
Keep in mind, the tractor hyd. pump on a CUT may be rated at 20+ GPM, but if you're using a remote to power the splitter, the flow may be only a fraction of that.
/ Thoughts on 3pt log splitters? #137
That's why my post above says, "at the remotes".
SR
/ Thoughts on 3pt log splitters? #140
That is one heck of a splitter!! You should be proud of that machine!
this started out for the bobcat splitter still has the mount, i made the T trailer and mounted the splitter on the trailer ,
if i wanted you can pull the bolts and the QD on the hoses and it can be converted back to the bobcat for the splitting,, I've built splitters
for any machine i had at the time, even one where it ran on my JD backhoe. this splitter has been around awhile
as the motor is a new one from HF .
2014 Dodge Ram 2500 Pickup Truck, VIN # 3C6UR5CJ6EG253763 (A65563)
2014 Dodge Ram...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2007 Chevy Suburban (A62679)
2007 Chevy...
