DEF for new truck
/ DEF for new truck #101
Unless I absolutely had to I would avoid any diesel truck that took DEF. I was so happy when I deleted the emissions of my, now sold, 2014 F250. If I had to buy a truck now it would be either a gas or diesel truck that's been deleted.
/ DEF for new truck #102
Oh boyyy, another DEF/SCR debate thread? yay, haha.
Oosik - congrats on the new truck! Post some pics, man.
Yeah, you really kicked ass on the last one….
“Reliable and Robust” seems to come to memory. :poop:
/ DEF for new truck #105
The two def jugs I have here that I haven't reused for water containers both have the 2 in a triangle on the bottom, HDPE ... that tells me they are recyclable ...
This is the style that comes in a box, and is quite wimpy plastic ...
This one is sold off the shelf ...
/ DEF for new truck #106
This sounds a little contradictory (from the linked pdf...)
Disposal:
If spillage occurs, the diesel exhaust fluid should be either transferred into a suitable container, or covered
using an absorbent material and then disposed of according to local environmental regulations. The container
must be labeled correctly. ï Do not empty into the drainage system. ï Do not empty/release into surface water.
DOESN'T SOUND TOO NON-POLLUTING...
/ DEF for new truck #107
Please explain. The engine "inhaled" the same amount of air it "exhaled", so how did it add air mass?
It converted some components of the air to other components. The net difference between intake total mass (air and fuel) and output (exhaust) should be essentially net 0 but when the carbon in the diesel combines with the oxygen in the air to produce CO2 then the net 'gain' of CO2 goes from almost zero to whatever the resulting mass is. And that's what they count. So, total mass doesn't change (much) but mass of "bad stuff" changes.
And though it is weird to think that they measure these things in pounds and get those huge numbers that are so much larger than the weight of the fuel going in, there is actually a LARGE mass of air used during combustion and that air has a weight to it. Essentially it is taking the volume of air in a room 13'x13'x8' high to burn each gallon.
One gallon of diesel combines with about 1300 cubic feet of air during combustion. That 1300 cu ft actually weighs 98 pounds. So you have 98# of air and 6# of diesel combusting to get probably about 104# of byproduct, some water, some CO, some CO2, some other gasses. That's how you can end up with 22-25# of CO2 from burning a gallon of diesel. Chemistry and fluid dynamics (of which air is part) can be kinda hard to think about.
Don't believe me or don't buy it? Ask some questions of your favorite AI chatbot and see what it says.
/ DEF for new truck #108
Air weighs ~0.0807 lbs. per cubic foot; CO2 would weigh the same + combustion remains. Got it.
That equates to a diesel engine intake of 272.6 cubic feet of air to burn 1G of diesel fuel.
The typical compression/diesel engine air to fuel ratio, under load, is 14/1, at idle can be 70/1.
Not sure where you got the 272 cu ft amount from, but it isn't what I found. I found my info here:
Where it says 1300 cu ft per gallon of diesel.
/ DEF for new truck #109
Yeah, you definitely don't want to spill the stuff. It wont kill you to touch it, or really harm the ecosystem if you spill just a little, but on your garage floor or equipment in the shop, it is nasty.
/ DEF for new truck #111
That's why I don't mind using them for water jugs for my trees, don't gotta be spic&span clean!
/ DEF for new truck #112
My new truck ( Ram 3500 ) is diesel. So - DEF is also in the picture. However - there is SUCH a wide range of prices between different brands. Examples ...... Kleen DEF - $56/ 2.5 gal. Blue DEF - $17/ 2.5 gal. For those of you, in the know. Is this price difference justified?
I Have been buying and using DEF from Runnings at $7 to $9 for 2.5 Gals. Never had a problem in my 2019 F150 Turbo 3.0L Powerstroke. Just remember DEF has a shelf life. I have my DEF stored in the garage (not climate controlled). Based on the info. below, that I just looked up, I 'm going move it to a cooler place.
Average Temperature Est. Shelf Life
Below 50deg F 36 months
Below 77deg F 18-24 Months
86deg F 12 Months
95deg F 6 months
Over 104deg F 2 Months or Less
Do an AI lookup for DEF facts for more info.
/ DEF for new truck #113
I use stuff from the pump . There ain't much to the stuff at the end. And if you get yours from a truck stop or somewhere that sells a lot of diesel, the def won't be that old either as all the new trucks use a lot of it. I've been using the pump stuff for several years without a problem.
It's half the price and if you put a lot of miles on your truck the savings adds up.
If you don't drive much then a couple of jugs might not be a big deal to spend the extra on.
Seems many aren't aware of def at the pump option.
/ DEF for new truck #114
Probably because they don't fuel at the pumps the big rigs use. I've yet to see a diesel/DEF pump in the section where autos and pickups fuel. I've been a diesel pickup owner for many many years and not once have I fueled with the big rigs.
/ DEF for new truck #115
I did ask chatbox, this is the result:
This confirms the AI stuff:
and,
/ DEF for new truck #116
Same here for the very most part. Unless the truck lanes look empty I stick with the car pumps, with up to a 38' trailer and all.
The professionals generally need to get where they're going more urgently than I do, so I don't want to be in their way.
/ DEF for new truck #118
My flatbed struggles to take fuel as fast as they put out otherwise I’d fill up there all the time. It takes forever to fill up my 50+ gallon tank with the regular pumps. Buc-ees has def at the regular pumps which is where I buy it
/ DEF for new truck #119
I use the truck lanes to fill up any chance I get, especially when towing the 5th wheel. I have a fleet card for RV'ers and it takes less than 2 minutes to fill up my Superduty with the monster nozzles. The truckers have been pretty friendly to me, I get in and get out quickly. The truckers do, on the other hand, like to pump their fuel and then go into the store leaving their trucks blocking the pumps...
/ DEF for new truck #120
I pull my truck right up to the pumps they use. The diesel pumps way faster and the DEF is about half the cost.
