Factory radio question
/ Factory radio question #1
Retired guy
Western, ME
CK 30HST
The radio in my ck30 HST does not play in the ACC position of the ignition switch. It only plays in the ON position. How big a
job is it to get it to play in the ACC position so I can listen to the radio while stacking the wood I hauled in from the woods. The cab
is factory. Does listening in the ON position do any damage if the engine is not running? Thanks
/ Factory radio question #2
I would not leave it in the on position without engine running. That position signals slot of electronics like the display computer, glow plugs, etc. just my opinion, not known facts. But i do know they tell us not to do that on cars.
ill have to check my dk45 and see … i dont recall that there was even a accessory position on key. Theres a off, run, start and additional glow plug as i recall. On my truck, theres an actual ACC position.
/ Factory radio question #3
I have the same issue. The other day I was wiring in an intermittent wiper switch and discovered a plug in the back of the cab that is powered in the acc position. I used that for the wiper switch that needed power. So, I was thinking that I would look for a wire in the roof first that goes to acc, then if not, I would extend the circuit I found up a pillar into the roof.
I used a spade lug and held it in with tape until I can find the proper connector. I think the plug is meant for going out to an implement control system but I don't know for sure.
I guess I should save up for the shop manual
/ Factory radio question #4
I take back what i said earlier….i do have an ACC position…..who knew.
manual says acc works audio system and work lights. The cigarette lighter and head lamps do not work with acc position. Now ill have to check this out.
/ Factory radio question #5
Guys, we spend $25,000 plus to buy a tractor, then thousands more on implements, then ***** about spending $300 so on an actual shop manual the size of three phone books that will answer most any question, seriously? Worse is so cheap that an owners manual is to even too much.
/ Factory radio question #6
Errrr. Sorry, I’m not sure what your trying to say
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2022 EZ-GO ELITE...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
