Face shield recommendations
/ Face shield recommendations #1
Shawn T. W.
SW Missouri Ozarks
Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
I wear prescription glasses, last pair was WELL over $500 ... Seems I usually forget to set my new pair down and grab the previous "damaged/scratched" pair of glasses when I pickup my trimmer, and get scratches and dings in them quite quickly!
I'm past due for a new pair of glasses, but reluctant to replace these I have, even though both lenses are "messed up"!
I want to buy some kind of "shield" to protect my glasses, and the rest of my face ... I've tried safety glasses over my prescription glasses, and goggles too, but they fog up ...
While I'm not really brand loyal ... Both my chainsaws, trimer and pole pruner happen to be Stihl brand ... I've looked at there helmets with shields, but they have pretty poor reviews ... I'm far from fashion conscious, so It's fine if it were Husqvarna brand for example or something else ...
I've also seen Bison, Oregon, Echo helmet/shields ...
I'm thinking I want a "mesh" style shield, but read that small stuff still gets through, but would it be enough to scratch my glasses ... Or should I get a solid polycarbonate shield? (It can get hot and muggy in Missouri!)
I don't really need a "hard hat" but it seems to be a good system to hold the shield in place, and I normally wear a cowboy hat to keep the sun off me, don't usually wear ear protection either, but the muff style never seem to really seal around my glasses anyways, use plugs when I mow though!
I'm running a Stihl FS91, it has the bicycle handlebars and I swing it both directions as I walk along my mile plus of fence, plus the usual around the house and driveway ... It does still have the guard on it, but it doesn't seem to do much!
I wouldn't mind spending $100 - $150 to save my next pair of $600 glasses!
Any recommendations?
/ Face shield recommendations #2
Buy actual glass instead of plastic lens.
OR; buy a plastic face shield from Harbor Freight.
I have 2 in my garage, 1 is a spare JIC I need a new one and HF is closed.
/ Face shield recommendations #3
I wear my chainsaw helmet with muffs and mesh face shield for weed eating. It's nothing special, Oregon brand. But it is comfortable enough I don't mind wearing it at all. I like the mesh face shield because it doesn't fog up when I am huffing and puffing and doesn't scratch. It also provides a little shade. Can't imagine anything that would damage your glasses would get in. Maybe if you were weed eating sand?? LOL
/ Face shield recommendations #4
Weed eating sand happens :rolleyes: around here if you cut real short:LOL: You learn to tilt the head and cut in the right direction to throw debris away from you after a while.
/ Face shield recommendations #5
Look at the Milwaukee bolt system also. I have their helmet, hearing protection and mesh shield set. A bit pricey, but worth it. Home Depot sells it. You can even customize it with shield type, muffs etc. Could reduce the cost significantly. I wear it over my glasses.
While the Milwaukee is pricey ... It has a lot of modular options, and it's proudly states "Made in USA"! That means a lot to me ...
I put the separate items in my cart at HD that I like ... They have choices of mesh material, choices of DB rated muffs for example ... Next time I'm due home, I'll probably pull the trigger on the order a few days beforehand ...unless I find something better ...
/ Face shield recommendations #8
Stihl sells a $100 arborist helmet that looks similar to the $229 Milwaukee posted above.
I have no idea what the difference between them is.
I have the Stihl. I wish the ear muffs were larger, I have to poke mine in to get it to seal up.
/ Face shield recommendations #11
I actually have a couple pair of those ... Never thought to use them for that ... I got them before I got my high dollar prescription sunglasses which I leave in my truck ...
I use to leave my prescription sunglasses in the truck as well, until the end of summer when the coatings started bubbling from the heat. So watch for that.
/ Face shield recommendations #12
I have a Stihl woodcutter hard hat with ear muffs and a mesh screen. It works great for weedwacking projectiles and brush cutting without fogging up.
For serious shop things I bought a facemask shield thing from Home Depot. It looks like this photo I got off the internet.
The face shield flips up. It's thick hard plastic intended for serious impact and has saved me from grinding metal and things like that. Eyesight is too important to risk.
/ Face shield recommendations #13
This looks decent! Face shields are one of those things you don’t think about until you really need one. I tried a few cheaper models before realizing comfort matters just as much as protection, especially during long tractor work sessions. A good adjustable headband makes a big difference when you’re sweating or moving around a lot. It actually reminded me of the time I had to contact Oakley customer service about replacement lenses — solid support can turn an average product into a long-term favorite.
Farmhand CG 3000 Tub Grinder / Bale Processor (A66408)
Farmhand CG 3000...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
(INOP) MCCORMICK FARMALL SUPER A TRACTOR (A64277)
(INOP) MCCORMICK...
213090 (A64276)
213090 (A64276)
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
(2) Lexion 7564961 Sieves and (3) 7574411 Grates (A65640)
(2) Lexion 7564961...
