Yanmar YM165D wheel replacement question.
/ Yanmar YM165D wheel replacement question. #1
Bazman72
Langley BC Canada
Yanmar YM165D
The right front wheel fell off my Yanmar. I guess it was loose and the movement caused the lug holes in the rim to wear and enlarge until the wheel fell right off.
I am trying to get the lug bolts off so I can put on another wheel but the square plate in the photo keeps moving / rotating and I can't get enough leverage to get them loose.
How can I stop the plate from moving?
/ Yanmar YM165D wheel replacement question. #2
Best to ask in the Yanmar section or on the YTOG.
/ Yanmar YM165D wheel replacement question. #3
the pic is so dirty and poorly lit it's hard to see what actualy broke.
Either way I had a 19hp kubota that the wheel was breaking around where it would touch the hub. I welded the wheel and it worked just fine for many years. It also had a front loader.
/ Yanmar YM165D wheel replacement question. #4
It looks to me like the front wheel hub is sitting on a stump in an apparent effort to use the weight of the front of the tractor to keep the hub from turning. If so, and that isn't working, I would use an impact gun. One other option would be to find a LARGE pipe wrench (the Menards close to me sells a 4' one that would work) to hold the square hub while using a breaker bar to turn to lug bolts.
/ Yanmar YM165D wheel replacement question. #5
Clean the manure off so it’s not so slick and use a crow bar across two diagonal bolts to keep it from spinning. If you don’t have a helper to hold the bar, then spin the hub until the bar is against the stump.
Just loosen each one so they can be used with the bar to hold for the next one, then take them all out.
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
Progressive Liquid Nitrogen Applicator (A66285)
Progressive Liquid...
