New machine!
/ New machine! #21
Took delivery of a John Deere 4052R with the “snow cab” today! Nice machine. Looking forward to heat and A/C! Replacing my Massey 1742. View attachment 4543935
Wow!!! That’s quite an upgrade!! Beautiful machine and what a beautiful barn!!!!
/ New machine! #22
Nice barn, show more !!
/ New machine! #23
If you do go with chains, and I suspect that you’ll need to, look into putting rubber stall mats on your epoxy floor. I have the same floor in my garage that I put 4 x 6 stall mats from tsc down for my Argo and for my snowmobile, especially with the carbides. I also use them in front of the entryway since they are easier to clean than the rough surface of the epoxy. Love the timber frame shop. Not much of a deere fan though :)
/ New machine! #24
Sounds like the general consensus is we don’t care about your new tractor as much as your nice barn.
/ New machine! #25
Heads up … make sure that left hand glass door is fully closed when pulling into the barn. (Ask my why I mention this ) 😀😀😀
Well, at least he won't be banging his cab on the header!
/ New machine! #27
“Heads up … make sure that left hand glass door is fully closed when pulling into the barn. (Ask my why I mention this ) 😀😀😀
So, I’m not the only one! Luckily I caught it in time and only put a NEARLY (except by me) unnoticeable tweak in the door frame.
/ New machine!
Now its time to invest in a set of tire chains. Both my tractors are bigger/heavier that your beauty but they are helpless in a heavy snowfall without chains on the tires.
I recently took the 4052R through my field with 20 inches of snow in it and it just chugged through it without a problem.
Like others I also noticed the nice looking shop along with your new tractor. I’ll show my ignorance on bigger JD’s, is a “snow cab” an option or is that just what you call it.
Snow cab was a term the dealer used. I had to have it serviced already due to a leak in the heater core. It’s fine now.
/ New machine!
I think we've seen some pictures of your barn in the past. Minor intererior pic iirc but enough to make an impression. 👍
That was the barn at the house we sold to our son. It was a very nice barn though it is stick built with rough hemlock. The new barn is three years old and is true timber frame with Douglas fir.
/ New machine!
I have an anti fatigue mat on the floor for the FEL bucket.
/ New machine!
The barn is very nice.
/ New machine! #32
How much snow will you be clearing? Any attachments besides the loader?
/ New machine! #33
TConnolly - that's an understatement, the barn is fantastic, the framing detail, lights - no wires, then the cars really add a lot of character!
Then your loft area - all very nicely done, Thank you for sharing!
/ New machine!
The cars belong to some friends of mine. They brought them over for a photo shoot for the builders advertising. It was fun!
/ New machine!
I’ll use the 4052 to move snowbanks and haul sand for sanding the driveways. We have four driveways to tend to. Longest is 500 feet. I have a JD X738 4x4 garden tractor with a 47 inch snowblower that I use to move the bulk of the snow. Just did 17 inches with no difficulty two weeks ago.
I also bought a 6 foot Frontier bush hog, JD pallet forks, and a three point wood splitter when I bought the 4052.
We have a number of other attachments too.
/ New machine! #39
Very nicely done down to the pegged flooring! I have 4 of the same Advents as part of an older audio system in my office.
How is your "barn" heated, as there are no ducts evident?
/ New machine! #40
If you do a lot of snow removal, you might want to consider a Rear Pull Snowblower. Perfect companion to that tractor
PS, you had me at Advent Speakers
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
213086 (A64276)
213086 (A64276)
2022 EZ-GO ELITE...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
