Water temp guage
/ Water temp guage #1
Hunter29
Michigan
Kubota B2920
Has anyone tried to install a second temp gauge with a readout while keeping the factory gauge in place?
I have looked at my D1305 and don't see a place to install another sending unit.
Is anything available to put in place by the radiator hose that would accommodate a sensor?
/ Water temp guage #2
I added a block temp gauge, just bolted to the block serves my needs
Temp Gauge
/ Water temp guage
Interesting, where did you bolt it?
/ Water temp guage #4
My LS had a bracket holding something near the firewall so I just used one of those bolts and routed the wire.
In my case the temp gauge in cluster will go crazy high (way past hot) or not move at all randomly. I'm guessing it is bad solder joint on the board since does it during self test randomly as well. The gauge I added is a sanity test, I know what range it should be 50-60C during hot operation and can keep an eye on it.
$30 vs $300 to replace the cluster seem an easy choice.
/ Water temp guage
Ok thanks
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
8' DISC HARROW (A60430)
8' DISC HARROW...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
2014 FORD E-350 11 PASSENGER VAN (A65643)
2014 FORD E-350 11...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
