R1, R3, R4, R14 - Tires - If you had to pick 1? 2?
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #1
FlyFishn
IH 444 gas
We're looking at getting a ~25hp CUT (B2601 and LX2620 are the top of the list).
Tasks will be general property maintenance - mowing, brush hogging, snow removal, material loading, logging, rear blade work.
However, we are probably going to down sizd our tillage to run with the smaller machine - 3 point passive implements like a plow, disk, cultivator and not live rotary like a PTO driven roto tiller. We may eventually do a roto tiller, either ours or borrowed, but by using the term "tillage" I mean tools pulled through the ground to do the work and not the PTO.
Friends of ours have R4 industrial tires on a variety of compact tractor sizes from a BX up to about 40hp and when I posed a similar question specific to mowing they all feel very comfortable with R4's over R3/turf tires.
What concerns me is the snow work and tillage. Snow I can add chains if needed. Tillage - Im not so sure on that one.
Thoughts?
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #2
For dirt work nothing will beat R1 for traction to put power to the ground under most working conditions. The lugs will bite in and clean better when ground is at less than ideal working conditions.
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #3
Ditto. I have R4's and they do pretty good but slip when I'm moving dirt around. R1's would allow you to take a better/bigger bite on say a plow or disc all other things being equal.
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #4
I have only used R4's, and I love them. If I leave chains on from winter into mud season, it helps with traction. Without chains isn't so bad either. What I like is the weight they can support, as I lift lots of heavy material. I had dealer swap out turf tires for R4 when I bought new.
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #5
On a B size Kubota or any ~25 HP tractor I would get R14s or R4s, in that order.
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #7
I think it obvious that in a field setting your best bet is going to be a set of R1's. However, it seems like your machine will be taking on multiple roles.
I suggest you look into Goodyear R14T's. I've found them to be excellent in both mud and snow, less likely to turn into a slick when operating in those conditions. I can tell you that I absolutely love them.
If I had to do it - how would those of you that have R14's or R4's feel about pulling tillage with them? 4wd will help Im sure. Ballast is another subject.
On the reverse of that, if we added ballast for the tillage we likely would want to remove that for mowing (the deck in and of itself will add some weight, not that we would really need/want it but it comes with the task).
The loader on the front is another subject. Im not sure we would want to remove it much, but from a ballast perspective - that would add some weight to the steer tires, speakng of tillage. Im just not sure Im looking forward to the bucking.
The rear end is another subject. Ive had suggestions of loading the tires. The problem with that is I cant remove it to mow.
Theres a point for the R1's - I could load them. But then they are almost a 1 task tire and I need the machine to run all year for everything.
My gut tells me to split the tasks and go R1's for the field work, then one of the other options (R14's. R4's, or R3's - maybe in that order of priority). But we're trying to keep the cost down. So if we had to pick one... are we going to be able to run tillage adequately, maybe with some creativity?
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #9
No offense intended . . . I really don't understand the conversation about "tillage" when talking about a 25 HP tractor. It's a perfect size for an appropriately matched tiller, but makes no sense for pulling a turning plow or serious ground-engaging equipment. Just doesn't have the HP or weight or size to do what I'd consider "tillage".
A tractor this size can best be used to work the soil by use of a rototiller. And it really shines in this role when ground conditions are right.
R14 or R4 tires (in that order) would maximize the capability and versatility of this tractor.
/ R1, R3, R4, R14 - Tires - If you had to pick 1? 2? #10
R1 all the way!
R4 tires are only intended for constant loader work on concrete or other hard surfaces to last. I have used tractors with R4 tires and they can get stuck on wet grass or the mildest of muddy terrain.
R1 tires can support all the load your loader will handle and still offer maximum traction. R1's are not a single use tire! That's what tractors only had for decades and did all the tasks well, many still do today, including mine.
R14 is the only other option I would even consider.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2008 New Holland T2420 (A60462)
2008 New Holland...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
Deere 331G (A53317)
Deere 331G (A53317)
1998 POLAR TANK (A60736)
1998 POLAR TANK...
