BCS failure point
/ BCS failure point #1
Craftsman 2 GT6000, BCS 735
I want to use BCS tractors for very hard work. Models would have locking differential and steering brakes. I should plan for spare parts and repair.
What are the designed failure points on the tractor and on the attachments? I’m thinking about things like shear pins on snowblower augers and post hole augers.
/ BCS failure point #2
Hi Big wheels are better ;)
I have seen in some of your other threads, that you are considering using your BCS 735 for some really hard work, making your question here a very valid one, but also a rather big one to comment on.
In the summer of 2011, I got a BCS 740, which I believe was a new model from BCS that year. It has the PowerSafe clutch, which was new at the time in Europe, and introduced in North America a year later. My experience is based on almost 500 working hours with this tractor, and with the 5 implements that I have gathered over the years.
In an electrical circuit, the designed failure point is a cheap fuse that will protect expensive components, should a malfunction occur. In a 2-wheel tractor, I’m only aware of the clutch to protect the engine and drivetrain, should something unpleasant happen. Some implements have shear pins or an overrunning clutch, that might/might not protect expensive components, depending on the type of mishap that you have.
I will list my implements, and try my best to comment on them in regard to your question:
My BCS Power Sweeper which I use primarily for snow removal in winter, has no build-in protection on its own, so working with this implement, the clutch is the „failure point“. I have never had a mishap with my Sweeper, but I feel that both tractor and implement are adequate protected this way.
My Berta 2-stage snowblower on the other hand, is protected by 3 shear pins! 1 for each half of the front auger, and 1 for the impeller. This makes sense, I think, as it sometimes is very difficult for the operator to see and avoid obstacles hidden in the snow in front of the implement. I also never had any issues with this implement.
My Berta flail mower does not have any protection on its own, so again here the clutch is the „failure point“. I have had a few incidents, where the rotor got jammed by fence wire and stopped almost instantly, but the clutch slipped for a second or two, until I could grab the handle and release it. No harm done to either tractor or flail mower (y)
My Zanon ZCR lawn mower has an overrunning clutch, which prevents the mower from powering the tractor through the PTO-shaft, in case the mower spins faster than the PTO. This has happened once for me, when a bolt came loose on the PTO-shaft, and it got jammed and stopped in an instant. The overrunning clutch allowed the spinning blades to slowly wind down, and at the same time, the clutch slipped, protecting the drivetrain and engine from a shock load (y)
My Zanon ZRF drum mower has a similar overrunning clutch as mentioned above. Once while mowing, one of the drums got jammed by a stone, and in that case, the overrunning clutch doesn’t help you at all, but again the clutch slipped, preventing further damage (y)
So to summarize, I have been saved a few times by the clutch, and it has probably also saved me a lot of trouble and costs. I am very happy with the way this clutch works, and it seems to protect the drivetrain and engine when needed.
Once the overrunning clutch on my lawn mower also did its job, and prevented an extreme torque load on the PTO-shaft, by allowing the heavy drums to spin slowly to a stop. The Zanon company probably hasn’t installed overrunning clutches on their mowers by accident, but because they are useful on „high-torque“ implements.
I would call my Sweeper and my snowblower „low-torque“ implements, which you can easily get up to speed, simply by applying a little throttle, and engage the clutch. The flail mower is sort of a „medium-torque“ implement, where you need a little more throttle, and you need to „feather“ the clutch a little, in order not to stall the engine. These implements are well protected by the clutch, I think.
„High-torque“ implements on the other hand, carry so much rotational inertia due to their fast spinning and heavy blades, that they might cause a lot of damage, when brought to an instant stop. The overrunning clutch allows the mower to dissipate the stored energy over perhaps 10-15 seconds, avoiding damaged parts and bent metal (y)
Sorry that this post got as long as it did, but I hope it helped answering an important question?
Best regards
Jens
/ BCS failure point
Hello and thank you!
I have zero experience with my machine. I read a lot and have a collection of BCS manuals. I bought it in poor shape to fix it. The low price is the only way I could afford a BCS. It came with the rotary hoe, 3 blade lawn mower and mowing sulky.
I love hearing all of the experience and seeing people use them. I’ll get there, eventually!
I’m hoping to add attachments over time. I’ll need a bigger model for some of them, though.
I’ll check into the clutch. Mine is older, so no Power Safe. It is the upgraded clutch. I wonder if it will slip, too.
/ BCS failure point #4
The only repairs I had to make so far were three. I kept shearing the auger pins on the snowblower for no apparent reason. Contacted BCS and they sent me new pins. They said the pins on the machine were probably not the correct steel. No problems since I replaced those.
A small part that captures the throttle cable where it attaches to the thumb control broke. I don't remember exactly what happened. I think it was aluminum. I just made a little steel sleeve to replace it.
Finally I broke the parking brake lever twice by snapping it to the off position. The aluminum lever just broke from the impact. I welded it and have since learned to gently release the brake lever.
I had to adjust the differential lock cable once. And to reversing cable once.
/ BCS failure point
Thanks. I think I remember that you use a flail mower. If so, do you use it on woody stemmed plants. I really want to get one (someday) and hope it can be used as roughly as my garden tractor belly deck. It’s absolutely abuse, but I cut elm trees as thick as around 1.5” with no problems. The stumps and too many stems together did cause problems, but no breakage. The tractor complained and told me to stop.
/ BCS failure point #6
No, I don't have a flail mower. That was above my budget. I just posted what I do in the land clearing thread.
/ BCS failure point #8
I have had a BCS 725 since 1993. I had a snowblower shoot brake and the engine guard rust and come off. I also till with it. I still have the same throttle and shoot cables it came with. It's probably the best machine I own.
/ BCS failure point #9
They are great machines, very innovative. No maintenance issues so far, but I’m only using a 4’ and 6’ sickle-bar cutters with the high flotation tire/wheel setup. The high flotation tires are absurdly expensive new, fyi.
The biggest issue you will have is when you reverse the handle bars to use the pto shaft for a front mounted implement like the cutters I use. The motion control is now reversed, which can be very dangerous. Before reversing the bars, to go forward, you push the lever forward and away you go. Pull back on it to go in reverse, simple and intuitive. With the bars reversed, when you push forward on the motion lever, which you do by habit from using every other machine you own, you are actually going in reverse. Pulling back on it makes it go forward, completely opposite of intuition and standard controls. A 14 hp machine weighing 350lbs will hurt you. I caught it and was able to stop it with minimal damage done to me after it had me pinned against a car. I looked for a way to switch controls to normal motion control with bars reversed, but found nothing on it. If you do find a solution, please post it. Good luck.
PS Remove and grease the adapter collar often if you use one. Leaving it on for too long will allow it to rust into place and becomes a bear to remove.
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2026 Kearney 7'x20' Trailer (A64119)
2026 Kearney...
UNUSED SDLANCH 14' PARTING IRON GATE (LION SCENE) (A64281)
UNUSED SDLANCH 14'...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
John Deere 8400 (A64126)
John Deere 8400...
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
