Replace agro couplers with flat faced?
/ Replace agro couplers with flat faced? #1
future_vision
Gold Member
New England
DK6010SE HSA
I have a Kiot DK6010SE and use the Kioti DKA144 3rd function kit. This has agro style couplers. 3/8″ ISO 7241-A Style Male and Female Couplers to be precise. I was thinking of swapping these out for flat faced couplers since the agro style is a real PITA. Should I do this? What about on the rear remotes?
/ Replace agro couplers with flat faced? #2
They are all a pita to some degree. IMO, you won’t gain anything but a lighter wallet unless you’re switching attachments between machines.
My thing is attaching the grapple on the front and the backhoe on the back. Always need to be using some type of cloth and a 'pressure applicator' to relieve the pressure so I can get the coupler seated. Not so worried about the couples at the loader. The loader rarely is taken off.
/ Replace agro couplers with flat faced? #4
If this seems to be a constant issue for you, then get some Connect under-pressure couplers.
You only need them on the implement-attachment side. You can always relieve the pressure on the tractor side. ;)
/ Replace agro couplers with flat faced? #5
Relieving pressure on attachment or tractor side? Me, I just use m/f couplers on tractor and on attachment then connect the attachment hoses together after unhooking.
Others use the Irwin Xboom q/c and others have modified different tools for the task.
/ Replace agro couplers with flat faced? #6
I have both types….both suck. I tried going with the type that can attach under pressure, but after buying the clamp style attachment tool, its no big deal anymore. But the last flat faced parker set i bought set me back about $190.
/ Replace agro couplers with flat faced? #7
/ Replace agro couplers with flat faced? #8
IMO, flat face couplers are more hype than substance.
/ Replace agro couplers with flat faced? #9
  • Good Post
Reactions: D&D
/ Replace agro couplers with flat faced? #10
I think the ONLY thing they do better is dribble and piddle less fluid. And maybe they support higher flow rates in larger sizes? I know I needed 3/4" rather than 1/2" FF on my excavator to be within the flow rate specs for the coupler..
/ Replace agro couplers with flat faced? #11
Oh, and the female side doesn't fill up with dirt and crap the way ag couplers do.
/ Replace agro couplers with flat faced? #12
A simple $2 rubber cap solves that.
Those should always be used, no matter the coupler.
/ Replace agro couplers with flat faced? #15
The issue on the implement side during storage is due to fluid pressure changes in the lines due to ambient air temperature changes or sunlight on the hydraulic lines. I made these with plumbing parts from a big box store and keep them on the implement(s) when not in use. They keep the connectors clean and the tiny hole drilled into the cap keeps the hydraulic pressure from building up. Before assembly, stuff the caps with a rag or paper towels to keep any hydraulic fluid from seeping out the weep hole.
/ Replace agro couplers with flat faced? #16
3 of my my Ag tractors come with a complex system of drain lines that connect in a bunch of plastic fittings that drain into a plastic reservoir. It ends up leaking and falling apart. Just a big mess.
All my tractor side female couplers have snap caps. Little dirt ends up in them.
I highly suggest the snap caps.
This looks like you are detaching the lines and leaving the couplers in place and attached to each other. Am I seeing this correctly?
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
2014 F-150 STX (A56438)
2014 F-150 STX...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A61567)
2025 HT360W Mini...
(APPROX.23) 2'/2"X8"X40" CHANNEL IRON (A62130)
(APPROX.23)...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A61567)
2025 Swict 66in...
