What's a VAC worth?
/ What's a VAC worth? #41
What the hell is a VAC
With all these acronyms you sound like the head tech guy at the last job i worked on. Every other word was 3 letter long, he might as well have been speaking french :p:cool:
JI Case tractor model VAC
Whenever I am looking at used equipment, I like to see it in its working clothes not all spiffed up. Paint can hide a lot.
I tend to agree with that. I suspect both of those VAC's have been repainted, one probably much longer ago?
/ What's a VAC worth? #46
A vac is a small tractor only about 19 hp It is rated a 2 plow tractor but my uncle who had a vai, similar machine but the industrial version, said a 2 plow was a little much. It can handle a 5' brush hog but a baler would be pretty hard on it.
19hp is pretty suitable for what I want I think. A square baler might be a bit much, but would be great for raking/spraying/cultivating. I have a couple other bigger 40-70hp tractors for anything serious. No plans on plowing with a VAC other than maybe a garden or so just for the fun of it. I guess I'll just try and see how it turns out.
/ What's a VAC worth? #48
If you care to share, what part of the country are you in?
/ What's a VAC worth? #49
The most memorable thing we did with it is run a big old circular saw w/ a tilt bed. Edit: Actually, that was the SC. But she made a lot of wood. Not a spec of paint on. You could rig the wife up a big old belt drive fan....
I didn't realize there were a couple different variations of the VAC. I've seen 2 different styles, I guess one is earlier model? It looks like the steering box is different from early to late models and the cultivator square behind the front wheels is different.
Is there any real difference between the earlier model and the later model VAC as far as function or parts availability? I see allot more early types than later.
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
John Deere 7200 6R Planter (A66285)
John Deere 7200 6R...
