Kubota F1900 outfront mower gearbox
/ Kubota F1900 outfront mower gearbox #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
The gearbox on my RC48F19 out front mower has shredded itself (seal failed, oil drained out).
Dealer has quoted a tonne of money to rebuild the gearbox.
I've found Snapper replacement gearboxes for around $200.
Does anyone have any experience either repairing the Kubota gearbox or using the Snapper gearboxes ?
Buying the new Snapper gearbox looks very attractive compared to paying the dealer for a repair job.
Shane
I have this problem again, any suggestions
/ Kubota F1900 outfront mower gearbox #3
Whatever it is you're doing to cause the failure - Stop doing it.
How did you resolve the problem last time ?
Where in NZ are you ?
/ Kubota F1900 outfront mower gearbox #4
Yikes. The gear box seals are on a schedule to be routinely replaced on my Kubota ZD mowers.
My ex-wife uses it, I have no idea what she's doing to it.
Paid the dealer
Kapiti
If I repair it again, I'll do just that
/ Kubota F1900 outfront mower gearbox #7
I am not familiar with F1900 / RC48F19, but had to find an alternative to the gearbox in my F3060 / RC72R-F30 mower.
Does the gearbox look like this, or is it the proprietary model they started using later?
My solution was new $150 gearbox from eBay:
90 Degree Bevel Gearbox on Kubota F3060 - 72" Rear Discharge Deck
I have seen some of the later model alternative aftermarket gearboxes on the eBay also, so it's worth checking out.
/ Kubota F1900 outfront mower gearbox #8
Paid the dealer
Kapiti
OK.
Kapiti - Long way away.
We have some 2H parts for units fitted to F3690 machines.
PM if you need to.
2019 GALYEAN...
500BBL WHEELED...
2021 Deere 333G (A53317)
2021 Deere 333G...
404 (A52706)
404 (A52706)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
