How do I get this boulder out of this hole?
   / How do I get this boulder out of this hole? #81
   / How do I get this boulder out of this hole? #82
What would be the approximate weight of an egg-shaped granite boulder about 8 feet long and 6 feet in diameter?
Google AI Overview
The egg-shaped granite boulder would weigh approximately 26,400 pounds (about 13.2 tons).
Bruce
   / How do I get this boulder out of this hole? #85
   / How do I get this boulder out of this hole? #87
We have big equipment now. They still argue how the Egyptians did it. But it was a lot of manpower and moving flat faces on rollers and sand. Just need to hire someone with a bigger track-hoe.
   / How do I get this boulder out of this hole? #88
That's the way to do it. Get down in there, carve that rock into an Easter Island statue, dig the ground out flat to daylight, get a couple dozen people and move that rock! ;)
Let’s have a TBN rally at the OP’s property and maybe we can see who’s got the most “farm boy” strength!
Don’t forget to pack your 100’ rope along with some clean tight-whiteys!
   / How do I get this boulder out of this hole? #89
Have to be quite the hoe to get that out of there whole, especially if he wants it to go anywhere else in the yard. He mentioned using it as a "focal piece in landscaping. That rock probably weighs a good 10+ tons. Biggest excavator I've run was a 40 ton machine and it would have struggled with that, even if there was a good way to grab it. It's possible, with the right machines, but it very likely is going to be really expensive. Gonna depend how badly he wants that particular "focal piece".
   / How do I get this boulder out of this hole? #90
Imo I think if you do get it out and where you want it, it will become a talking point instead of a focal point.
2025 CFG Industrial MH12RX Mini Excavator (A56857)
2025 CFG...
JOHN DEERE 7100 - 6R PLANTERS (A58374)
JOHN DEERE 7100 -...
2020 Takeuchi TB235-2 (A55272)
2020 Takeuchi...
6' SCRAPE BLADE (A52708)
6' SCRAPE BLADE...
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
