X730 lack of rear flashing lights
   / X730 lack of rear flashing lights #1
sriddle1
SW New Hampshire
ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
I’m searching for the best solution to make-up for the shortfall in the X730 design, no rear flashers. I live in rural NH and we have some very hilly & winding roads so I need the best safety protection while I’m cutting or plowing along the road. On the X730 each rear light housing consists of a RED Lens and a Clear Lens. When going in reverse the bulb under the clear lens activates, also when choosing the “All Lights On” selector switch the bulb under the clear lens activates. Wondering if I can replace the clear lens JD UC12940 bulb with a 3157 amber flashing or strobe bulb (if there is such a thing). I’m not concerned about the reverse light function. If this is possible, I’d simply select the “All Lights” when working along the road and hopefully a bright LED amber bulb would be flashing, to alert drivers coming up behind me. Question, since I know nothing about LED Bulb Design is there a bulb that flashes or strobes when power is applied. Thanks
   / X730 lack of rear flashing lights #2
Beenthere thanks for the response, not in their road, as stated: I’m cutting or plowing along the road. That means where the end of the driveway intersects the road. I'm hoping someone can answer the question about a flashing 3157 bulb.
   / X730 lack of rear flashing lights #4
I meant being in the road ROW (right of way). But you have a plan so wish you well going forward with that plan.
   / X730 lack of rear flashing lights #5
I believe European version of X7** have turn signals so makes me wonder if wiring is there just need to figure out where flasher plugs in.
Maybe they have completely different circuit boards.
oldnslo, Thanks for the response, yes, I also read the euro version had turn signals and I believe a flasher selection, I'll have to research that. It would be nice if I could find a flashing LED bulb, one that flashes when power is applied and doesn't need a separate flasher unit, if there's such a thing. The "All Lights On" selector certainly supplies continued power to the clear lens in the light assembly. Before buying this '22 X730 I owned a true workhorse, a 425 that had flashers, really miss that machine.
   / X730 lack of rear flashing lights #7
Google search showed some flashing bulb options but not sure if they flash continuous or for a few seconds and then go solid. I.e. brake application
I recently went from X540 with no tail light to X738 So the lights to me are an improvement.
Cushman Electric Cart (A55853)
Cushman Electric...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Honda UTV (A56859)
Honda UTV (A56859)
2008 Mercury Milan (A56859)
2008 Mercury Milan...
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
2015 Yale 5K Forklift (A56435)
2015 Yale 5K...
