2640 Slips out of Park
   / 2640 Slips out of Park #1
Sopater
John Deere 2640
I have a 2640 that occasionally slips out of park. Not sure why.
A neighbor has one of these on his 2640 that he says holds it in park, but I don't know what it is... any ideas?
PARK LOCK ASSURANCE KIT
  • SIDEBYSIDE_PAULA_HODGE_25NOV2025_2216597134824.pdf
   / 2640 Slips out of Park #3
Looks like a home made rigging that physically holds it in park. Jury rigged.
Welcome to TBN
   / 2640 Slips out of Park #4
Welcome to TBN
No. That was JD answer to it coming out of park. Our 2440 did not have that. When it was recalled to have it installed my grandfather signed off a waiver not to have it. I hear those have issues. When we parked our on the hill to unload sap you made sure it was in park. It never came out. But I could bumping the lever getting off could have tragic results. There was a slight detent it sat in when in park.
Welcome to TBN
It looks like JD created a Park Lock Assurance Kit. See the PDF file in my second post. I found that after my original post. I was hoping that there was something I could adjust or replaced, but I might need to see about getting that kit. Otherwise, I just need to not park it on a hill and rely on the PARK setting of the shifter.
   / 2640 Slips out of Park #6
After rereading your post here are my thoughts. Don’t update it. Leave as it is. When you put it in park. Don’t just push the lever straight up and leave it. Make sure to move it straight up and to the right. With the lever there pull it straight back. It should not go to neutral. If I recall from my childhood. Those updates had an issue with releasing the range lever.
That was the most important instruction we were given as kids when parking the sap tank on the hill. Make sure you can’t pull the lever toward you before getting off the tractor.
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
