PART SEARCH
/ PART SEARCH #1
snake699
Satoh Beaver
New to group. Thanks for acceptance.
I have a Satoh Beaver and need a radiator. no luck finding anything. Does anyone know of aftermarket radiators available. Aluminum or steel. Just need to find one reasonably priced. Tractor runs perfectly.
/ PART SEARCH #4
You could also hunt down a local radiator shop. They may be able to either repair your old radiator, or help find or make one that would fit. Perhaps even get you an upgrade in the process.
/ PART SEARCH
/ PART SEARCH
Unfortunately been that route. It's actually at the shop now. Sadly, not fixable. Corroded beyond salvation.
/ PART SEARCH #7
So, a tractor from the 1970's, it probably originally had a brass/copper radiator.
The last radiator I had repaired was a little shop in Fort Collins, Colorado that looked like it was 50+ years old. He unsoldered my upper and lower tanks. Measured everything. Ordered a new core to be overnighted from Denver. The next day he sand blasted my tanks, then soldered it all back together, pressure tested it, then painted it, and I installed it and was on my way that evening. I thought the core was custom made, but it could have been a stock size.
That was in about 2007. It wasn't particularly cheap. I don't remember the exact amount, but I think it was around $500.
/ PART SEARCH #8
You can go with used stuff, or new. For used, there is that E-Bay link above.
Based on Carl's description, this appears to be a rather similar tractor:
Oh, that one is here in Oregon. ;) It is worth calling them.
/ PART SEARCH #9
If you wish to try to adapt something different, take some detailed photos of your radiator, front, back, and side, and overlay measurements on the side with the most detail.
/ PART SEARCH #10
I don't suppose you have a parts manual for it, or have found one online, the easiest way for me to find parts for older tractors is to use the OEM part number and use the Google search engine to enter the part number, helps to put it in quotation marks. You never know what will pop up.
/ PART SEARCH #11
Thanks for the reply. That radiator is too big but gives me a good idea of more manufacturers to search for something that might fit. the KE70 is only 669cc. Quite a small radiator.
There's one on ebay now for your tractor $225 - its the second link I posted above where its "pardon the interruption"
/ PART SEARCH #12
check yesterdays tractors, They may be able to help you.
/ PART SEARCH #13
When a branch went through my Chinese tractor's radiator from the back side, I ended up just going through online sites until I found a radiator that fit the spot and had fittings on it that were close enough. I ended up with a Kubota radiator, and it only took a couple hours of work to modify the mounts and hoses to get it to work. I also eliminated the belt fan and added an electric fan at the time. It's been working for years, and cost me less than $100 for everything.
/ PART SEARCH #14
Try searching for tractor junkyards on Google maps and check with them
What size is your radiator
2022 EZ-GO ELITE...
2007 Econoline Trailers Trailer (A62613)
2007 Econoline...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Outback Guidance System (A65640)
Outback Guidance...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
John Deere 1023E (A62177)
John Deere 1023E...
