42F with abundant sunshine @ 12:30, calling for a high of around 43F for the day. Low this morning was 27.2F.
Woman announced She was making pancakes yesterday morning and inquired as to whether I wanted any.
"Sure ..."
Big mistake ... passed out for several hours on the couch ...
Finally got moving around 16:30 and got down to the basement.
Floor had dried up, scraped the debris loose with a mud knife and gathered that up in a dust pan.
After that I hit the floor and a small section of wall with a wire brush and then vacuumed that up.
Then scrubbed the remaining salt off the lower section of wall with some plain water and a scrub brush.
Then trained the fan and halogen lights on that to dry it up real quick.
Discovered the bottom one of the legs on the stationary tub had rusted away so I stuck a chunk of 2 x 4 underneath it to jack it up and support it.
Changed out furnace filter.
Located the breaker for that next wall outlet and turned that off then pulled the outlet, electrical box, and conduit down off the wall.
Got the next section of foam board trimmed out for the HVAC line that goes through the wall to outside and then got that glued up, placed, and braced.
Marked out locations of studs on the next 8' bottom plate and took some measurements for the studs.
Pulled the extra water filter element that had been soaking in Iron Out and got it rinsed off and set it on the dish rack to dry.
Was around 22:00 at that point so I called it quits for the day.
On the agenda for the rest of the day:
Fire up torpedo heater and get the garage warmed up so I can start cutting the next batch of studs to length.
Refill hopper feeder and probably both suet feeders.
Collect up seeds which are now dry from the last Mammoth Gold pumpkin we processed and get those put away.
Clean off another pumpkin and get it in the oven, then process it in the food processor once it's cooked, and package it up for the freezer.
Gather up trash/garbage to go up to the cans.
Beyond that just see what else comes up.
Hope everyone is having a decent Monday ...
