How many acres was an 8N designed to farm, when new?
/ How many acres was an 8N designed to farm, when new?
Yep, it's a different world now. The farmer that farms across the road from me, farms 4,600 acres and we have a 3,500 cow Dairy in this county.
I know. Even in my short memory, the local ranches in my area have either gotten bigger, or gone out of business altogether. There used to be a lot of them, but the last few years have been hard; very dry around here. We still haven't had our first snow this year; usually it happens around mid-october. Even the mountain ski resorts are getting a bit worried by the low snowpack levels.
/ How many acres was an 8N designed to farm, when new? #62
Those little N model Fords were considered "chore tractors" by my family in S,Dak.
160 acre dry farm
What part of SD?
My grandfather's family had 320 acres on one farm. 160 from the Timber Culture Act of 1873 and 160 from the Homestead Act of 1862. Day County. I've got family all over the state.
/ How many acres was an 8N designed to farm, when new? #63
What part of SD?
Brown and Spink counties. And for the past 45 years, Walworth on the east bank of the river.
/ How many acres was an 8N designed to farm, when new? #64
My uncle and Dad both started out with horses when they were younger then Dad went to steel mill in 1930’s uncle had 60 dairy cows. Both split the original dairy farm/ orchard. Dad sold some of his off to build house, my uncle roughed it out, horses to 9N to several 600-800 series an then to a 3000 in 1969. Farmed 100 acres until the day he died in 1993. 3000 tractor sold with the hour meter turned over twice 😏
/ How many acres was an 8N designed to farm, when new? #65
I don't see any kind of location in your profile. You talk about your location but no hint of where it is. Please add a location in your profile.
/ How many acres was an 8N designed to farm, when new? #66
My 1950 8N is a working tractor, not a restore although I have given thought to getting a new hood and painting. It is 3 yrs older than me and I have had it for about 28 years. I use it a lot in cutting and moving my yearly firewood and snow plowing.
I bought one of those dearborn front plows but I have added my own design front mount pump and a frame to use hydraulics for raising and power angle. I made a frame to mount the rear of the plow frame that bolts to the transmission/rear end area and braces to the rear end.
Again no garage queen about 8 yrs ago i added saturn vue power steering unit and that was a game changer for these arthritic shoulders and hands.
22 years ago I converted it to 12volt and that electronic points replacement.
In doing firewood I used a homemade 3 pt set of forks to move pallets of wood.
After adding the hydraulics I made and added a double acting cylinder that mounts to the tractor just above the pto and goes to a second hole in all my 3 pt implements, I can raise anything without having to shift to neutral. The original lift is functional I just leave it down and out of gear when using the add on. If you think about it, it is just letting the 3pt go up like it normally would if you say were pulling a rake and it hit a high spot.
Lastly it came with the sherman over/under/direct transmission and I think I paid about $4000 in about 1997 with a ford finish mower and a ford rear blade.
5 years ago I bought my L2501 but the 8N gets used about 50% of the time still.
Bill
/ How many acres was an 8N designed to farm, when new? #68
My dad, in partnership with his brother, mainly owned a dairy farm in NE Minnesota where the primary industry is iron mining. In the 1930s and 1940s there were thousands of people working in the mines, and each miner had a family. My dad picked up an International Harvester dealership and flooded the area with Farmalls. Small farmers, flat area with poor clay soil (in the late 1800s and early 1900s logging was king) but there was demand for fresh milk. Our main competitors were Allis-Chalmers and Ford with very few John Deeres. Now that I've required from my engineering career and moved back to my home area for retirmeent, most of those farms have been abandoned - there are only 2 dairy farmers within 90 miles. One neighbor, also returned from the big times as an OTR trucker, has his father's farm including 4 Fords. My nephew, one of the two remaining dairy farmers, is still using an M and an H my dad sold for things like pulling hay wagons around the farm. But when you were using horses for farming, a Ford 8N was a big step up. I remember having 3 widowed neighbors trying to maintain the family farm - husband KBH - killed by being kicked in the head by a horse. Although rear rollovers with Fords and flipping their tricycle IH's sideways were too common, still safer than horses.
/ How many acres was an 8N designed to farm, when new? #69
Bill
Interesting on the VUE PS. My guess it wasn't all that difficult to setup! Mentioned I was going to most likely add PS. All Elec. and 02-07 complete steering columm 197$. Could very well possibly a game changer!! I'll be looking into it.
/ How many acres was an 8N designed to farm, when new? #70
With all its use back in the day, I would Not recommend an 8N to anyone for actual use today. Not when MF 135s, Ford 2000s, ect exist, at nearly the same price; and are miles ahead in usefulness
/ How many acres was an 8N designed to farm, when new? #71
My sister and family have a Dairy farm in northern WI. It has grown to around 1,500 cows. It seems you expand or get out.
/ How many acres was an 8N designed to farm, when new? #72
Right in the old stomping grounds, especially Brown and Spink. We played Mobridge sometimes, too. Of course that would have been right about when you added Walworth Cty.
I don't remember seeing any old timers using an 8N. Grandpa had AC, Massey, and IH tractors. The old stuff around there was similar. JD was rare except the newer models. (70s)
/ How many acres was an 8N designed to farm, when new? #73
Since Ford designed the tractor to replace a team of horses I think the N series was considered good for 20 to 60 acres, I personally know of two that farmed about 40 acres. IMHO the biggest factor being how many hours one would be willing to spend in the seat.
I raked a lot of hay with a 8N back in the 60s for my Uncle. I don't remember him using that tractor for much else other than a small bush hog.
/ How many acres was an 8N designed to farm, when new? #74
If you go back, you tend to see that farms had more acres back in the day. Then, many farmers divided their land among their sons. You saw a lot more places with 160 ac or less. Hard to make a living on those small farms, especially if you are trying to grow the same crops/critters that dad grew.
Farmers also used to be much more cooperative. A few farmers would share equipment and labor, especially with harvesting or cattle branding/roundup. Starting in the late 60s, more farmers seem to want to buy their own everything. Costs went up, but the economy was OK, so people got by. Late 70s started to destroy a lot of those small farms. Equipment got bigger and more capable of handling larger fields in less time (and/or with fewer hands). The smaller guys either sold their land or specialized in niche crops.
That trend continues as the more successful farmers bought up the failed farms. Where problems really came in was land speculation and 'corporate' farms.
To be fair, most successful farmers today have at least an LLC if not a Corp. When I say corporate farms, I mean corporations that bought out local farmers and manage them from afar. The value to them is more the land and the government assistance.
/ How many acres was an 8N designed to farm, when new? #75
1948 was when grandparents got their first tractor and 25 years later it was still sickle-bar mowing for the small 30 milk cow dairy farm.
They still talk about all the timber sold to make the purchase… but timber regrows and grandfather was not going to part with land.
My cousin left farming selling all the livestock and has a very good life selling off the farm homesite by homesite.
Another cousin… a Porsche mechanic restored the 1948 tractor so that part of history is preserved…
/ How many acres was an 8N designed to farm, when new? #76
Amazing how different parts of the country provide different opportunities and risks.
Trees were so scarce in the Dakotas (and some adjacent areas) that the government gave away 160 acres if homesteaders would plant 40 acres of it in trees. In the East River parts of both states you still see farms with big shelter belts of trees originally started in the late 1800s.
Selling trees wasn't an option, but it sure was a smart idea for those who had it.
Agreed, the scale of modern agriculture has grown incredibly. I remember hearing somewhere that 60% of American farmland is owned by farms with over 2,000 acres. In a way it's kind of a shame, it represents the large corporate shift seen in America in the past 50 or so years.
/ How many acres was an 8N designed to farm, when new? #78
The "corporate farm" issue is complicated. Yes, there are some massive corporations running ranches, feedlots, chicken farms, etc. However most of the crop farms are really family farms but they have incorporated because in modern USA that's the only rational way to run a large business.
/ How many acres was an 8N designed to farm, when new? #79
You want a kinda smart butt, but also true answer to the original question? You can farm exactly the same ammount with a mule, an 8N, a Massey 135, or 9R, or Big Bud. Two weeks is what you can farm. Name your slowest operation; tillage, planting, harvesting, you can farm as much acres as you can cover in 2 weeks.
So, mule team; about 15-20 acres; 8N about 80 acres; Massey 135, maybe 160 acres; John Deer 9RX maybe 2000 acres.
So, two weeks is how big you can farm.
Towable Centrifugal Water Pump (A59228)
Towable...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
24in pin on tooth excavator bucket (A61306)
24in pin on tooth...
Towable T/A Flammable Liquid Transport Tank (A59228)
Towable T/A...
