Good morning!!!!
   / Good morning!!!! #214,232
67°F and 2.72 inches rain. Definitely been wet and soggy. Much needed, but forecast is we might get a break later today.
Of course the weather gives excuse for my back. Maybe someday I’ll get it checked out but have lived with it so long the only time I even think about it is when it acts up and I pop ibuprofen for a few days.
So another energy conservation day ahead
Prayers for all
Be safe
Have a great tractor day
   / Good morning!!!! #214,233
No. All Torx drivers are the same geometry, but there are many other "star" drive types.
"Torx" is a standard, with 6 teeth. But there are many other standards, some pretty common, which look a lot like torx but aren't.
Yes, six teeth is standard for Torx, as well as a few of the other common variants. But I also have several with 5 teeth, and others (e.g. Timberlok) with higher tooth counts. Here's a TimberLok driver bit with 8 teeth, which is very common in framing:
That one's new to me, as well! But it makes perfect sense, I like it!
Years ago I bought a bit assortment similar to this that had every style bit you can imagine even security bits, hollow Torx different #splines, everything.
I still use it occasionally and there were two businesses close to mine (cabinet maker and landscaper) who would borrow it. I never had to fight with an odd fastener again.
   / Good morning!!!! #214,234
   / Good morning!!!! #214,235
good morning, 58 going to 60 wind up to 13 MPH
Keeping the fire on low to take the chill out
Stacking of wood continue with good progress on the second row. Using 4x4 x 10 feet posts for bookends.
Still doing laundry and domestic chores
today will look some more on aligning the post vise. Not sure if the yoke can move up higher without getting it glowing hot to get it to conform
   / Good morning!!!! #214,237
Good (Sunday) morning. Overnight Low of 5.3C and it's presently 13.1C [heading to 18C], partly cloudy and calm this A.M. There was 1.5mm in the gauge @ 0600.
As per usual, I'm off to Church in a few minutes and then the rest of the day is His.
   / Good morning!!!! #214,239
Got pilot oil changed, and air in the low tire. The fronts looked low but were ok, but back right was low and didn’t appear to be low. Must have been how it was sitting.
Draining rest of water collected in the IBC tote before cold weather.
Dead bird was floating in it, got it out.
Gathered SD cards, still got a buck out back.
Decided to grill burgers, looked away and flames got away, but not too well done.
Wife had already ate at something she was at.
Tiger laying on my lap, he has rarely done that , usually he lays on footrest between my legs.
   / Good morning!!!! #214,240
What’s wrong with the pickup that she thinks you should trade it?
Needs body work mostly both rear fenders driver side rocker panel,knuckling sound from the rear end not u joints 115.000 miles little TLC here and there,heck I think pickup barely broken in. :)
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
AUCTION STARTS HERE @ 9:15 AM (A58374)
AUCTION STARTS...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
ASV RT-120 POSI TRACK SKID STEER (A52709)
ASV RT-120 POSI...
