Tie Rod End Boots GC 2610
/ Tie Rod End Boots GC 2610 #1
DJRussell
Member
Calgary, Canada
Massey GC2610
I don't make many posts, since the GC 2610 has been basically bulletproof, but recently both tie rod end boots have torn, or worn out. The dealer does not sell just the boots, he sells the entire tie rod end, and the price is quite high.
Has anyone found boots that will fit the GC 2400/2600 series and where do we find them?
I do live in Calgary, Canada, but could likely purchase them from the USA if necessary.
Regards
Jim
/ Tie Rod End Boots GC 2610 #2
I found this site https://www.suspension.com/universal-dust-boots.asp ... I was going to order from them, but I had more pressing things to do, then my nut that holds the tie rod on fell off, and ruined itself, I decided to just buy new tires rod ends for both sides ...
I was getting by with a few shots of grease in them when they were tore up, but after this "field repair" I decided to just replace everything!
/ Tie Rod End Boots GC 2610 #3
I believe there's some universal ball joint boot kits you can mail order inexpensively if you want to just re-boot them.
/ Tie Rod End Boots GC 2610 #4
trust me when I say full tie rod assemblies are a lot cheaper than 2 tie rod assemblies AND a steering cylinder.
while there make sure your hub rotate limit bolts are snug and not ready to fall out. that can cause a ton of cylinder damage.
ask me how I know.
edit: I did replace both ends due to finding crud incursion and since replacing cylinder at same time...meh. the threads can strip very easy, only a 10mm thread so keep in mind if reusing old ones.
Gentlemen
I thank you all for your input. After looking at the pictures, I realized I incorrectly called these tie rod ends. My mistake, they are actually the boots at the ends of the hydraulic steering cylinder. Probably the reason the dealer said they only came with the tie rod ends.
I actually found them online at a fairly local Massey Dealer, and although the price is exorbitant, they will definitely fit. I believe I will cut up a bicycle tube to wrap around the new boots to prevent them from getting too much UV exposure from the sun.
Once again, thank you for your input. This forum is great.
Regards
Jim
/ Tie Rod End Boots GC 2610 #7
yeah cyl end does have replaceable 40$ boot. you will have to hold piston of cyl with a skinny (very skinny) 19mm against the wrench flat that is on one side of piston to keep from spinning when doing this. iirc its left side as mounted. only one end of piston has the wrench flat.
the cover (part 4265169M1) fits over end (part 7069211M91) and end is threaded INTO piston with its own wrench flats on end 7069211M91. you have to remove end from piston both sides to replace cover. you must keep piston from rotating.
if its easier think of it this way. you are dealing with an inner and outer tie rod. the boot area you dealing with is the inner tie rod end. that inner end W/O boot is 150$. the boot is 40$.
anyways last year new cylinder and all tie rods (inner and outer) cost me approx 1800$ all driven off limit bolt falling off hub.
Thanks Dave M. I will use your advice on installing the new boots. And I will definitely make sure those limit bolts are tight. Don't want them coming loose.
Jim
/ Tie Rod End Boots GC 2610 #9
Jim
missing bolts with a rock stuck behind steering cylinder 2k$ w/ my cheap ass labor.
knowledge how to avoid this BS priceless :)
The boots arrived a few days ago, and I installed them with very little difficulty. Once the locking nut had been loosened, it was relatively easy to remove the "threaded rod" portion from the actual tie rod end. The ball joint turned easily, allowing the removal of the threads. Cleaned up the ball joint, regreased, and slipped the new boot over the joint. Old clips were used to complete the boot install, and then rethreaded the joint back together.
Overall took about an hour and a half for both sides. I did check the limit bolts on the steering, and they were tight.
Hopefully these boots last as long as the originals.
Thanks everyone for their help.
Regards
Jim
2013 Ford Escape AWD SUV (A61569)
2013 Ford Escape...
2011 FOREST RIVER SIERRA CAMPER TRAILER (A60736)
2011 FOREST RIVER...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A60352)
2015 Peterbilt 348...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
