Ideas to dispose of land clearing waste
   / Ideas to dispose of land clearing waste #41
Have you talked with them about a controlled burn? They start and watch over it.
The VFD does that here. They did it for me, years back, for a small donation to the department. I called them because I had some huge piles of trees and brush. They came out with a fire truck and stayed for about three hours.
I'm in the county and they have "no burn" rules during dry spells but controlled burns are ok. If I'm burning brush, I call them to let them know in case someone reports smoke. I've been doing that way since I lived here--1999.
   / Ideas to dispose of land clearing waste #42
We don't call anyone ...
I sometimes burn early in the morning, not to hide it, but I'm awake, and the wind is cut down ... 3-4 am when the nearest neighbors 1/4 mile away are sleeping anyways ...
A foggy day usually has high moisture content on the ground, and would hide the smoke and flames from any distance ...
   / Ideas to dispose of land clearing waste #43
Man, you mix fog and smoke, and visibly goes to Zero. We had a peat bog fire burning about 11 years ago, and it burned underground for about 5 months. On foggy mornings it was a guessing game that road was shut down that morning based on wind. One time, it was so bad I pulled over, and from the White line, I couldn't see the yellow line, 12 ft away...
   / Ideas to dispose of land clearing waste #44
If you have any local campgrounds nearby, they might take some of it for campers to burn. It doesn't need to be a hardwood for those purposes.
   / Ideas to dispose of land clearing waste #45
I've been clearing some land for awhile. As a result I've accumulated a lot of organic waste. Hiring someone to haul it off is going to be too expensive. What I can burn, no larger than 5" diameter, I have been. What I need to figure out is what to do with the rest of it. As you can see in the attached images I have a lot of waste logs which I don't think are worth trying to process for firewood. Besides, I've got a ton of good wood to process and just don't have room for this other stuff. I also have piles of roots, grass, small rocks, twigs, etc that also need to go. I was thinking of renting a 12" chipper to handle a lot of the wood but if anyone has better ideas I am open.
Advertise around “free firewood-bring chainsaw.”
2018 Kubota U17 (A53317)
2018 Kubota U17...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A57193)
UNUSED FUTURE MINI...
2017 Ford E-450 Super Duty Shuttle Bus (A55852)
2017 Ford E-450...
2018 GENERAC MLT6SM-STD3 LIGHT PLANT / GENERATOR (A52707)
2018 GENERAC...
UNUSED PABREAK SBR160 SAND BLASTER (A57193)
UNUSED PABREAK...
UNUSED FUTURE MINI EXCAVATOR RAKE (A57193)
