fordcomanche
Member
My 1955 Ford 850 had its front axle pin welded in by prev owner.
I bought the tractor in 1980 and wasnt too concerned about it back then, but now 45 years later, that center bushing needs replacing badly!
I attached some pics, the axle pin looks to be welded on both front and rear side of the axle support. I cannot tell if this was originally a threaded pin or smooth pin.
The tractor is blocked and secured and I have the front axle and the axle frame support swung out from tractor.
Trying to decide what to try first-
-Should I try to grind out enough of the weld off front and back to break the pin loose
-or try to cut thru the pin on both sides of the axle/bushing so that I can fully remove the support frame from the axle.
Has anyone had to deal with this before? Even once I get this out and replace the bushing, not sure how to secure the new pin in place. I would hate to have to weld it in again.
Thanks in advance for any ideas or suggestions
