Ideas to dispose of land clearing waste
   / Ideas to dispose of land clearing waste #11
I’ve given away a bunch of logs off clearing jobs. It’s easy to do this time of year.
   / Ideas to dispose of land clearing waste #12
Hardwood? yes
Pine? not easy
   / Ideas to dispose of land clearing waste #13
   / Ideas to dispose of land clearing waste #15
The cheapest option is to burn but that also takes the most time.
If you want fast, hire a 30 ton excavator to dig a big hole and bury everything. You can then rent a forestry mulcher to do final cleanup. Would probably be cheaper than hiring someone to haul away...around here at least.
In my area you need a CDL to haul over 10,000lbs truck and a CVOR and commercial insurance. $500/yr just to get your annual inspection done...not cheap anymore...even farm plates are now forced into annual inspections.
   / Ideas to dispose of land clearing waste #16
Seems like that would be a massive hole to bury all that and make all that land worthless to build anything at least near that hole because of decomposing wood for how many years
   / Ideas to dispose of land clearing waste #17
Yea I wouldn’t burry that mess. Where I live it usually isn’t possible to dig a hole that deep but my dad tried that about 20 years ago a few counties over where you actually can dig a big hole. That hole is probably still sinking as the wood rots. For a couple years it was settling a lot like several feet at a time. I would clear a bigger spot and just shove it all in the corner out of the way before I buried it.
   / Ideas to dispose of land clearing waste #18
I agree on the BioMass Energy plants - there are several in New England. When we had 4 acres cleared they chipped everything except the logs and sold the rest to Shiller Station in Newington NH for 30$ ton - took 6 tractor trailer loads of chips. Shiller stopped taking wood waste in 2024, but depending your location there are plants in ME MA and CT that still burn wood waste.
It's a matter of getting it chipped. I would rent a large chipper - 12-14" and feed it with an excavator - probably get a lot chipped in a few days. For the rest of the dirt/roots/rocks burning is best - just get a few piles going and keep feeding it for a few days.
Then dig a hole and bury the remaining bits that dont burn. It's a lot of work clearing ground - what are you doing with the stumps? That was my biggest cost - $1750 a tractor trailer load 4 loads.
   / Ideas to dispose of land clearing waste #19
We can burn but nothing larger than 5" radius. A lot of those logs are bigger then that. As for the other materials there is a lot of dirt mixed in and it tends not to burn.
Are the cops going to come if you start a fire with pieces over 5”? If you piled up a pile as big as a truck, let it burn down some and repeated the process you would be done in a couple days. It’s going to take much longer to chip that with anything less than a belt feed behemoth chipper.
You can buy a dump truck cheap, then sell it when you are done. Or hire a local to haul logs to processor.
Even a 26,000 GVWR dump truck (no CDL required) can haul 6 tons of logs at a time.
Non-CDL dump trucks are easy to sell since anyone can drive them.
Logs are lighter than stone, dirt or sand. A dump truck loaded with logs has lots of air space, so the loads don’t weigh all that much.
It's the cost of disposal that can add up.
2017 John Deere 5090GN (A53317)
2017 John Deere...
MAHINDRA MAX 26L LOADER (A57192)
MAHINDRA MAX 26L...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
