Rolling basket?
/ Rolling basket? #21
We had a three, and two 2 inch pipes a little wider than the disc connected with chain and eye bolts that would drag behind the disc.
Just pick them up and lay on top of disc for transport
I have a heavy piece of old railroad iron that I use like that but it's no match for the way a rolling basket smooths the field.
/ Rolling basket? #22
How much land are you working. Not a lot I doubt with a 5 foot disc. What's the big deal with another pass? My second pass would without a doubt be with a tiller. Nothing smooths the ground or breaks up clods like a tiller.
/ Rolling basket? #23
With that size tractor I think you'll be stuck doing 2 passes with the different implements to get your desired results.
Sent from my SM-S921U using TractorByNet mobile app
/ Rolling basket?
We till up probably 20 acres total. This is an ex-pasture, and the farmer disked it all after we bought it, so it was plenty bumpy at first. We've only had the place for 2 years, and it's smoothing out okay now.
The spike harrow I have, was assembled out of three (real old) horse drawn sections abandoned here. I've got a bunch of old iron/implements here, that survived the WWII scrap drives. They were left here and a 20" maple tree grew up through one section. I had to cut it apart with a cutoff tool, and left quite a bit of it in the tree... I'm pretty proud of the job i did to cut the savable parts and make two of them usable. It actually gets towed behind my Polaris Ranger. Yes, the drier (and the faster we go) the better.
I also have a 3 pt tiller. I was just exploring other options.
/ Rolling basket? #25
I wouldn't mind owning one
/ Rolling basket? #27
seems like it would take a lot of HP to pull both at the sane time.
/ Rolling basket? #28
/ Rolling basket?
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2010 Nissan Rogue SUV (A61569)
2010 Nissan Rogue...
207280 (A52708)
207280 (A52708)
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
44052 (A55852)
44052 (A55852)
