Tractor just shut down out of nowhere
   / Tractor just shut down out of nowhere #1
duffer
Aiken, SC
'16 Mahindra 2538
Yesterday after I finished mowing, I was putting the mower back under the lean-to, and out of nowhere the tractor just shut down. Like somebody turned off the key. No warning light, no beep, no engine coughing, nothing.
So my first thought was one of the 238 safety switches went bad, and I'd take 3 days tracking it down. Or...the alternator just blew.
I called my neighbor who is a jack of all trades mechanic, and he suggested I check the ECU wire going to the battery. Because the ECU controls everything. (I thought the ECU ran off the alternator but not the case) Sure enough the extension bracket on the battery, where 4 other connections are made, had broken off from the battery terminal.
Replaced the battery terminal (which took far longer than it should have because it's so damn tight in there. Had to remove some stuff) made the new connections and all is good.
Hope this helps someone that may experience this sort of phenomenon.
   / Tractor just shut down out of nowhere #2
Glad you made it work. But why is it tractors are getting so tight in there? It's bad enough cars have gotten that way. One of the nice things about working on tractors is -- or should be -- that you can get to stuff!
   / Tractor just shut down out of nowhere #3
Any idea why the extension bracket on your battery broke ? Any pictures you could post of it ?
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
1992 Pine Dry Van Trailer (A55852)
1992 Pine Dry Van...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
