Big Case tractors
/ Big Case tractors #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Saw this today on a construction site. Big tracked Case IH tractors pulling scraper pans. It used to be the tracked Challenger tractors doing this but lately it’s been tractors more like these . The building an area for staging and storage for a new power line project. I assume storm water detention is what the big hole is for. I believe there were 5 of these rigs running around.
/ Big Case tractors #2
I've seen that before, it's cool to see those large ag machines working in construction. Given their size and weight, they must do great pulling those scrapers.
/ Big Case tractors
If you look in the first picture there is a wet area, I noticed them spinning a little in this area. It’s been very dry around here, I’m not sure what the plan was if we had a wet fall.
/ Big Case tractors #5
View attachment 4329471View attachment 4329472
That’s because the Challenger line was discontinued about 4 years ago.
What AGCO has done is replaced them with Fendts.
/ Big Case tractors #6
Did AGCO ever make scraper models of twin tracks or was that discontinued when AGCO purchased challenger line from CAT?
/ Big Case tractors #7
Yes. Here’s one with a CAT C-18 motor. It was just the opposite. When AGCO purchased Challenger from CAT, they only had the single track models. AGCO then created a dual track articulating model.
Case-IH has a big hold on my area, so about1/2 the pull-pans are pulled by Case-IH quad tracks. I also see Deere pulling lots of them.
Saw a few Challengers, but they had a bigger presence in other areas.
CAT really was rolling when they had AG tractors and even had trucks going back about 15+ years ago. Then they jumped out because they couldn’t make their engines meet the reliability-killing over-burdensome EPA regs.
Cat's new Quadtrac - Coffee Shop - Red Power Magazine Community
/ Big Case tractors
I did some topographic surveying in front Caterpillar plant when they first started making Challengers. I’m not even sure where it was, I was working for our Rockford Illinois office, it was maybe east of Rockford. That was the first I’d ever seen a tracked ag tractor. My memory was it was a smaller plant but they had a bunch of them outside, maybe this was late 80’s early 90’s.
/ Big Case tractors #9
We were using the Case Quads with scrapers in 2000. Had a serious undercarriage failure rate with the 440 model. It showed up new about a week before 9/11 at the new Catholic school on Rt 40. Front idlers would melt the shafts from bearing failures.
I think they improved it when they went to the 450. I believe we started with 2 used 9310's for proof of concept. A contractor in Southern PA was using Cases but with flotation singles. Trouble was that made the tractor wider than the scraper.
/ Big Case tractors #10
Dekalb - sycamore Illinois was the challenger assembly plant that I knew of. There could have been others.
/ Big Case tractors #12
Yep. That's similar to what they did to level the ground for the battery plant and data centers going up near us.
/ Big Case tractors #13
That sounds right, it seems like it was out in the middle of nowhere.
They have a plant in MN and a plant in GA.
My big Challenger was made in Duluth, Georgia.
They also have the Hesston plant in Kansas.
My small Challenger was assembled in France, but has CAT 3056 American engine.
/ Big Case tractors #14
The CAT Challenger plant was in Dekalb - Sycamore , Il area. AGCO moved it to Jackson, MN when they purchased it.
/ Big Case tractors #15
About 25 years ago while I was the project manager for Fire/Security, at our local Nissan Powertrain Assembly Plant, Turner Universal brought in several tractor to pull the pans where the plant was expanding. It was a 1mil sq ft expansion. None of use had ever seen this done and were amazed at what they did with this.
/ Big Case tractors
Traditionally they used rubber tired scrappers and usually had a bigger dozer to help push them through the cut. This still happens today but it seems like less so. I think the longer the haul distances the better the rubber tires scrappers work.
/ Big Case tractors #17
In central Arkansas we see all colors of tracked tractors pulling dirt pans. The rice farmers are always trying to level their fields. Imagine the difference in water amounts in a field a 1/4 mile wide with 6" difference in elevation.
/ Big Case tractors #18
Not much else in Jackson. A truck stop along I90. Been through there a lot.
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
1994 CUSTOM FAB 94" X 14' GOOSENECK HORSE TRAILER (A62130)
1994 CUSTOM FAB...
